At what range does a conservative force contribute to the thermal U?
In summary, the conversation discusses the definition of a system containing deformable bodies and how the total energy can be expressed as the sum of mechanical and internal energy. The distinction between macroscopic and microscopic perspectives is also mentioned. The conversation also addresses the question of where to draw the line for negligible forces and the idea of considering a snapshot of the scenario. The contribution of gravitational potential energy to thermal or mechanical energy is also brought up.
etotheipi
Suppose we define our system to contain a few deformable bodies that exert gravitational forces on each other, and are consequently moving towards each other in some vague sense.
We might want to express the total energy of the system as the sum of the mechanical energy and internal energy. From my perspective, the gravitational potential energies would contribute to the mechanical part, and the intermolecular electric/gravitational/etc potential energies within the bodies themselves would contribute to the internal energy. Just because from this perspective, the macroscopic/microscopic distinction is more obvious.
However, we could have just as easily zoomed way way out of the above scenario, and considered all of those deformable bodies to make up one larger deformable body, with a fixed COM (no external forces). Now, we can just as easily say the system has no mechanical energy, and only internal energy.
So how do we draw the line? I'm aware that I'm probably misinterpreting a few things so please do let me know if this is completely the wrong outlook. Thanks!
Science news on Phys.org
There is NO such line. The affect of force gets smaller with distance (typically as 1/r^2) but there is no point where it is 0. You will have to decide when you want to declare that the force is "negligible" yourself.
Likes etotheipi
You're right, suppose instead we paused time and considered a snapshot of the scenario. The magnitudes of the gravitational forces between each deformable body would then be fixed.
It seems the gravitational PE between the various deformable bodies could be considered as a contribution to the thermal energy or the mechanical energy of that system.
Related to At what range does a conservative force contribute to the thermal U?
1. What is a conservative force?
A conservative force is a type of force that does not dissipate energy and can be fully recovered when the object returns to its original position. Examples of conservative forces include gravity, elastic forces, and electric forces.
2. How does a conservative force contribute to thermal energy?
A conservative force does not directly contribute to thermal energy, as it does not dissipate energy. However, when an object experiences a conservative force, it may undergo a change in potential energy, which can then be converted into thermal energy through friction or other non-conservative forces.
3. Can a conservative force contribute to thermal energy at any range?
No, a conservative force can only contribute to thermal energy when there is a change in potential energy. Therefore, it can only contribute at ranges where the object experiences a change in potential energy, such as when it is moving in a non-uniform gravitational field or when it is compressed or stretched by an elastic force.
4. How does the range affect the contribution of conservative force to thermal energy?
The range does not directly affect the contribution of conservative force to thermal energy. However, the range can indirectly affect it by determining the amount of potential energy that can be converted into thermal energy. For example, a longer range may result in a greater change in potential energy and therefore a larger contribution to thermal energy.
5. Can conservative forces be converted into thermal energy without any non-conservative forces?
No, conservative forces cannot be converted into thermal energy without the presence of non-conservative forces. This is because conservative forces do not dissipate energy, so they cannot directly contribute to thermal energy. Non-conservative forces, on the other hand, can dissipate energy and convert it into thermal energy.
  • Classical Physics
  • Classical Physics
