Qaiphyx
- 92
asdf
asdf
cristo said:What?![]()
phlegmy said:well for starters i don't know for sure. but:
yes generally stell weakens as it gets hotter, and becomes softer.
when its cooler it becomes stronger, but more brittle
also something can be quite strong and yet very brittle, i know it sounds strange but glass for example is actually quite strong, but as most ppl know, quite brittle.
also a quick google threw up
http://cr4.globalspec.com/thread/5058
Consdiering they use different materials in different temperatures for that very reason, they differ quite a bit.Qaiphyx said:Right so there should be an average point of temperature that a certain material is most structurally sound right? Where its less likely to break when induced to kinetic energy. How much could different steels differ?
Qaiphyx said:Like, steel at 240 degrees is weaker than at room temp, cause the heat energy weakens the bonds in the metal, or like when you hit it with liquid nitrogen and hit it, it will shatter, cause the bonds become weaker at those temps than at room temp.
Qaiphyx said:How much could different steels differ?
Mapes said:Qaiphyx, you're overly simplifying the question of maximum strength. There's no one number that reaches a maximum, then decreases. The tensile strength decreases with increasing temperature, while the fracture toughness increases with increasing temperature. The optimum temperature will vary depending on load, load rate, geometry, even surface finish.
The bonds are not weaker at low temperature. Rather, the bonds are stronger and less ductile, and it becomes favorable for a crack to propagate right through the material instead of terminating in a plastically deformed area.
Certainly a huge amount! Take a look at any metallurgy textbook, I think you'll find it very useful in clearing up your questions.
The melting point of steel can vary depending on the composition of the steel, but on average it ranges from 1370 to 1530 degrees Celsius (2500 to 2800 degrees Fahrenheit).
Steel begins to lose its strength at temperatures above 400 degrees Celsius (752 degrees Fahrenheit). This is due to the process of thermal expansion, where the molecules in the steel begin to vibrate and move apart, weakening the structure.
No, steel does not become stronger at higher temperatures. In fact, it becomes weaker as the temperature increases due to the process of thermal expansion.
The optimal temperature for forging steel depends on the type of steel being forged, but it typically ranges from 1200 to 1300 degrees Celsius (2200 to 2400 degrees Fahrenheit). This temperature allows the steel to be manipulated without losing too much of its strength.
The carbon content in steel has a significant impact on its strength at different temperatures. Higher carbon content steel, known as high carbon steel, is stronger at room temperature but becomes more brittle at higher temperatures. On the other hand, low carbon steel is less strong at room temperature but maintains its strength at higher temperatures due to its greater malleability.
