At what times does the object intersect one of the coordinate planes?
For the xy-plane, you need to find the values of t for which z(t) = 0. For the xz-plane, you need to find the values of t for which y(t) = 0.
ShakeECET109
r(t)={sin(pi*t),ln(t),((1/4)e^t}
At what time(s) does the object intersect one of the coordinate axes?
At what time(s) does the object intersect one of the coordinate planes?
During what times t is the object in the first octant?
Not sure??
I know points on the z-axis have the form (0,0,z). The curve will intersect the z-axis if x(t) and y(t) are both 0 at the same time (t value). Same for the x-axis and y-axis.
Points in the yz-plane have the form (0,y,z), the x-coordinate of the point must be 0. So for this I need to find the values of t for which x(t)=0. Same for the xy- and xz-planes.
I really am not sure how to start. Can anyone point me in the right direction?? Formula maybe?? Or show me an example done using a position vector?
Not sure??
Your reasoning is correct, so you have already made a good start. Your vector function r(t) lists x(t), y(t), and z(t). For the first problem you need to have sin(pi*t) = 0 and ln(t) = 0 for the same value of t.
A point is in the first octant if all three coordinates are positive.
sin(pi*t) = 0
sooo sin(pi*t)=ln(t) , then solve for t?
ln(t) = 0
ShakeECET109 said:
sin(pi*t) = 0
ln(t) = 0
No, you don't just want the points at which sin(pi*t) = ln(t) - you want to solve the system of equations
sin(pi*t) = 0
ln(t) = 0
Ohhh soo...
[URL]http://www2.wolframalpha.com/Calculate/MSP/MSP118919ha265g6c4b58g80000500gabba95c6h992?MSPStoreType=image/gif&s=23&w=156&h=18[/URL]
[URL]http://www2.wolframalpha.com/Calculate/MSP/MSP119419ha265g6c4b58g8000022fg02efc8adeba9?MSPStoreType=image/gif&s=23&w=500&h=22[/URL]
so x and y are 0 when t = 1 and I have to do the same for the x and y-axis because that was for the z axis?
any help on how to find when it intersects a plane??
Your image links are bad.
ShakeECET109 said:
Ohhh soo...
Yes.
Do what you described in post #1
FAQ: At what times does the object intersect one of the coordinate planes?
What is the meaning of intersecting with a coordinate plane?
Intersecting with a coordinate plane means that the object's path or trajectory crosses or touches one of the coordinate planes (x-y plane, y-z plane, or x-z plane) in three-dimensional space.
How do you determine the times at which the object intersects a coordinate plane?
To determine the times at which the object intersects a coordinate plane, we can set up equations for the object's path and the equation of the coordinate plane. By solving for the values of the variable(s) at which the two equations are equal, we can find the times at which the object intersects the plane.
Can an object intersect more than one coordinate plane at a time?
Yes, an object can intersect more than one coordinate plane at a time. This occurs when the object's path crosses through the point of intersection of two or more coordinate planes.
What are the implications of an object intersecting a coordinate plane?
An object intersecting a coordinate plane can provide important information about the object's position, velocity, and acceleration at a specific point in time. It can also help determine the object's path and trajectory in three-dimensional space.
Are there any special cases or exceptions when determining the times of intersection with a coordinate plane?
Yes, there are certain special cases or exceptions that may arise when determining the times of intersection with a coordinate plane. These may include situations where the object's path is parallel to the coordinate plane or when the object's path lies entirely on the coordinate plane. In these cases, the equations used to determine the times of intersection may have no solutions or infinite solutions.
