Atmospheric air pressure on the human body
In summary: So, in summary, atmospheric pressure is very strong but it doesn't matter whether an organ is solid or liquid because the pressure inside is the same as the pressure outside.
fog37
1,568
108
Hello,
It is well known that the atmospheric air pressure is significantly strong but our body does not get crushed by it because and equal pressure pushes from the inside our body.
That said, does it mean that air can exist and be diffused inside solid organs like the lungs, our heart, etc. and exert its pressure as it would without permeating the organs? Is the pressure inside the solid body parts equal to atmospheric pressure? How does that happen? Does air diffuse through solids like that?
Thanks!
fog37 said:
Hello,
Thanks!
No, air doesn't need to be inside your organs to balance atmospheric pressure. Think about a well-filled water balloon; It's just a bag of water.
Yes. Our lungs, and also other animals use Oxygen from the air, and excrete CO2.
Handily, most plants do the reverse process.
Ok, so, not be crushed, the internal pressure of the organs inside our body must balance the atmospheric air pressure. I thought that would be possible because we inhale air at the same pressure as atmospheric pressure and that air did the balancing, not the solid stuff inside the organs...
There is no reason why the organs in your body, which are mainly water, would be subject to any pressure differrrnt to ocean water
Ok, so in the ocean the pressure of water at a particular depth is the air pressure + rho*g*h where h is the depth. Close to the water surface, the water pressure is indeed atmospheric pressure. Back to the inside of the body, as most organs are made of water, their internal pressure will be approximately atmospheric air pressure. Is that the reasoning?
Yes, but it's fascinating that animals evolved lungs, which work by producing small pressure differences, enabling what we call respiration..
No, solids and liquids have pressure of their own.
These things don't follow. It doesn't matter if the interior of your body is water or solid calcium salt (your bones). It has the pressure it has because the atmosphere is applying pressure to it, so it applies pressure back.
The reason we can generally ignore this pressure is that it is uniform, so it doesn't cause any internal stress.
To be precise, the partial pressures of the dissolved atmospheric gases in our tissues is the same as the partial pressures in the atmosphere. If the ambient pressure changes then there will be (slow) diffusion to re-establish equilibrium. Decompression sickness is caused by changing the ambient pressure too quickly for the diffusion to be fast enough to prevent the formation of bubbles.
All our tissues (except, perhaps dental enamel) are composites and have some water in them. We are more like a wet sponge than a lump of steel, in that regard. But I think you could say that a solid like a block of metal would absorb some atmospheric gases eventually. The timescale would be greater than geological, though and equilibrium is never reached. The same is almost true for the special oils made for high vacuum technology.
Related to Atmospheric air pressure on the human body
What is atmospheric air pressure?
Atmospheric air pressure is the force exerted by the weight of the air in the Earth's atmosphere. It is measured in units of pressure, such as pounds per square inch (psi) or millibars (mb).
How does atmospheric air pressure affect the human body?
Atmospheric air pressure affects the human body by exerting a force on the surface of our skin, as well as our internal organs. This pressure can cause discomfort or health issues, such as headaches, ear pain, and respiratory problems.
What is the ideal atmospheric air pressure for human health?
The ideal atmospheric air pressure for human health is around 1013 millibars (mb), which is considered normal sea level pressure. However, the human body is able to adapt to a range of pressures without any major health consequences.
How does atmospheric air pressure change with altitude?
As altitude increases, atmospheric air pressure decreases. This is because the weight of the air above decreases as the distance between the Earth's surface and outer space increases. For every 1000 feet increase in altitude, air pressure decreases by about 1 inch of mercury (inHg) or 33 millibars (mb).
Can changes in atmospheric air pressure affect athletic performance?
Yes, changes in atmospheric air pressure can affect athletic performance. High pressure can make it more difficult to breathe, leading to decreased oxygen intake and potential fatigue. Low pressure can also affect athletic performance by causing joint pain and stiffness.
17K
  • Mechanics
