Graduate Atmospheric Density Required for Mercury´s Polar Regions to be Warm?
  • Thread starter Thread starter snorkack
    Mercury Poles
Mercury's thin atmosphere results in extreme temperature variations, with daytime highs reaching +430°C and polar lows dropping to -170°C. Unlike Venus, which maintains a consistent temperature due to its dense atmosphere, Mercury's weak atmospheric heat transport fails to keep the poles warm. Theoretically, a denser atmosphere could raise polar temperatures to +20°C, but it would need to be thinner than Earth's to avoid overheating due to proximity to the Sun. However, even with a suitable atmospheric density, the ground temperature may remain significantly lower than air temperature, making it uninhabitable. Ultimately, the unique conditions on Mercury, including its long nights and lack of tilt, complicate the potential for a stable, livable environment.
snorkack
TL;DR
At which atmospheric density would Mercury´s poles be neither hot nor cold?
Venus has a dense atmosphere (about 90 bar).
Although Venus has a low axial inclination and the poles of Venus are therefore always in twilight, the day side atmosphere heats to about +460 C and the heat transport at the 90 bar atmosphere is so efficient that the poles are no more than 10 C cooler than day side.
Mercury has a thin atmosphere.
Day side of Mercury heats to about +430 C; but the poles are only around -170 C because of thin atmosphere and weak atmospheric heat transport.
At which atmospheric density would Mercury have just enough heat transport to provide for +20 C at poles?
Astronomy news on Phys.org
Interesting point, that with the right atmosphere the poles might be livable, but we know the atmosphere must be thinner than Earth because Earth is about the place where you get good (but not complete) sharing of heat. So if it was like Earth, and way closer to the Sun, it would be too hot. So if it's going to be thinner than Earth, it probably wouldn't be all that livable after all, but at least it could be temperature.
Note also that if you use a weak atmosphere to share the heat around, it might not be enough to raise the temperature of the ground. Let's say an atmosphere like Mars could warm it up to +20 C, but that would be the air, the ground would still be radiating away so could be much colder. In other words, there is a density where the T of the air is right, but if that density is too low to get the ground to come to that T, then the ground T could still be much lower. You probably wouldn't care what the T of the thin air was if you are walking around on -100 C ground.
But your question also points out something else that's interesting-- since the T of the actual Mercury goes from -170 to +430, there is a latitude where it already is +20 C. Since Mercury's axis isn't tilted, that place is always at +20 C, except for the darn eccentricity of the orbit. If it were a circular tidally locked orbit, there would be a curve on the surface of Mercury that was always +20 C, all the time, with a nice big Sun close to the horizon all the time. If not for the lack of air, that might be an interesting spot to hang out. Or, given how long Mercury's day is, maybe it would be possible to keep moving on its surface such that you always stay somewhere that is +20 C. It's not something you think to do on that supposedly hot planet!
No, there isn´t. Because of the 88 day nights. In the equatorial regions, the surface hears to +430C in the afternoon - and manages to cool to -160 Celsius by morning.
At high latitudes where the Sun is low, daytime may only warm to +20, but night is still 88 days, so necessarily even colder than at equator.
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 21 ·
  • · Replies 67 ·
