Atmospheric Lapse Rate (calculating the altitude of cloud formation)
In summary, the conversation discusses the calculation of freezing level and cloud base. The standard temperature lapse rate is 3.5 °F or 2 °C per thousand feet up to 36,000 feet according to FAA. The dry adiabatic lapse rate is 5.4 °F per 1,000 feet, while the wet adiabatic lapse rate is 2.7 °F per 1,000 feet. The conversation also mentions the concept of temperature inversion and its impact on stability.
Borborygmus
This is probably more of a p-chem question but I figure you guys are smart enough to answer this.
FREEZING LEVEL CALCULATION:
Per FAA "A standard temperature lapse rate is when the temperature decreases at the rate of approximately 3.5 °F or 2 °C per thousand feet up to 36,000 feet"
Easy enough to use this to calculate freezing level.
CLOUD BASE CALCULATION:
"As moist, unstable air rises, clouds often form at the altitude where temperature and dew point reach the same value. When lifted, unsaturated air cools at a rate of 5.4 °F per 1,000 feet and the dew point temperature decreases at a rate of 1 °F per 1,000 feet. This results in a convergence of temperature and dew point at a rate of 4.4 °F. Apply the convergence rate to the reported temperature and dew point to determine the height of the cloud base."
Also pretty easy.
But wait does air cool at 3.5F or 5.4F per 1,000ft??
I think the issue here is whether we're talking about dry lapse rate or saturated lapse rate. Or an average. Per wikipedia, looks like 5.4F is dry, wet is 2.7F.
So my question is, wouldn't it be better to calculate freezing level by using 5.4F until you get to cloud base (which is saturation level) and then switch to 2.7F?
As I understand the nomenclature, the "standard temperature lapse rate" refers to a typical rate of change of temperature with altitude. We are not talking here about how temperature changes as a parcel of air rises, but the temperature profile of the actual atmosphere.
The "dry adiabatic lapse rate" or "unsaturated lapse rate" refers to the rate of change of temperature of a parcel of air that is lifted and cools from adiabatic expansion.
If the actual temperature profile in the atmosphere were to have a gradient in excess of 5.4 degrees Fahrenheit per 1000 feet then that would constitute an inversion. Low altitude dry air could rise, expand and cool and still end up warmer than the high altitude air that it displaces. Obviously, such an inversion would be unstable. An actual dry gradient of 3.5 degrees Fahrenheit per 1000 feet is less than 5.4 and, so, is stable.
Likes Dale
I understand an inversion to be warm air on top of cold air. So the temperature gradient would have to be negative i.e. <0.
A skew-T chart shows the temperature over air pressrue as measured by a weather balloon. I'm not very good at reading these, but found this example
http://www.atmos.millersville.edu/~lead/SkewT_HowTo.html
In the sample graph, the actual lapse rate (red line) seems to mirror the trend of the adiabatic lapse rate (background lines) up until 200 mb at which point we see a temperature inversion. 200 mb is the end of the stratosphere and beginning of the troposphere which always has a temperature inversion.
Related to Atmospheric Lapse Rate (calculating the altitude of cloud formation)
1. What is the atmospheric lapse rate?
The atmospheric lapse rate refers to the rate at which the temperature of the Earth's atmosphere decreases with increasing altitude. It is typically measured in degrees Celsius per kilometer (°C/km) or degrees Fahrenheit per thousand feet (°F/1000 ft).
2. How is the atmospheric lapse rate calculated?
The atmospheric lapse rate is calculated by dividing the change in temperature by the change in altitude. This can be done using the following formula:
Lapse Rate = (T2 - T1) / (Z2 - Z1)
where T2 and T1 are the temperatures at two different altitudes (Z2 and Z1) and the resulting lapse rate will have the same units as the temperature and altitude measurements.
3. What is the standard atmospheric lapse rate?
The standard atmospheric lapse rate is approximately 6.5°C/km (3.5°F/1000 ft). This means that for every kilometer increase in altitude, the temperature of the atmosphere will decrease by 6.5°C. However, the actual lapse rate can vary depending on factors such as location, time of day, and weather conditions.
4. How does the atmospheric lapse rate affect cloud formation?
The atmospheric lapse rate plays a crucial role in cloud formation. As air rises in the atmosphere, it expands and cools due to the decrease in atmospheric pressure. This cooling causes water vapor in the air to condense and form clouds. The rate at which the air cools is determined by the lapse rate, so a steeper lapse rate can lead to more rapid cloud formation.
5. How can the atmospheric lapse rate be used to predict weather patterns?
The atmospheric lapse rate can be used to predict weather patterns by indicating the stability of the atmosphere. A steep lapse rate (greater than the standard 6.5°C/km) indicates an unstable atmosphere, which can lead to the formation of thunderstorms and other severe weather. A shallow lapse rate (less than 6.5°C/km) indicates a stable atmosphere, which is less likely to produce significant weather events.
