Atmospheric pressure and weight measurement
In summary, the conversation discusses the significance of atmospheric pressure being referred to as 100kPa and the discrepancy between the force required to raise mercury by 76 cm and the weight it exerts on a digital weighing scale. The response explains that the scale does not need to be adjusted because the pressure acts on all parts of the scale, resulting in a net pressure force of zero.
cyriac
Whats the significance of Atmospheric pressure being refereed as 100kPa ? Does that really mean 10000 kg/m2 acting upon us ?
If we are measuring only collision force on the surface and not the weight of the entire column of air above us, then why figure 100kPa (100000 N force/m2) which is huge and significantly more than what is required to raise mercury level by just 76 cm
"Why 100kPa?" That is what is measured.
The density of mercury is 13.54 g/(cm^3), so a square meter of mercury with 76 cm thickness weighs 10300 kg, and would need a force of 101000N to lift it up.
Hi
Thanks for replying
Then why a digital weighing scale doesn't pick that force. When we stand shouldn't it pick up 80kg + 10000kg ?
Or is the scale being adjusted only to reflect body weight
cyriac said:
Hi
Thanks for replying
The scale doesn't have to be "adjusted." The pressure acts on all parts of the scale, including parts facing downward (which receive an upward force from below). The net pressure forces on the scale are zero.
Likes CWatters and davenn
Related to Atmospheric pressure and weight measurement
1. What is atmospheric pressure?
Atmospheric pressure is the force exerted by the weight of the air in the Earth's atmosphere. It is measured in units of pressure, such as pounds per square inch (psi) or pascals (Pa).
2. How is atmospheric pressure measured?
Atmospheric pressure is typically measured using a barometer, which is a device that measures the weight of the air above it. The most common type of barometer is a mercury barometer, where the height of a column of mercury in a tube is used to determine the pressure.
3. What factors can affect atmospheric pressure?
The main factors that can affect atmospheric pressure include altitude, temperature, and weather conditions. As altitude increases, atmospheric pressure decreases. As temperature increases, atmospheric pressure decreases. Changes in weather, such as the presence of high or low pressure systems, can also affect atmospheric pressure.
4. How does atmospheric pressure affect the weather?
Changes in atmospheric pressure can influence the movement of air masses, which can lead to changes in weather patterns. Areas of high pressure generally correspond to clear, sunny weather, while areas of low pressure can indicate the potential for storms and precipitation.
5. What are some common units of measurement for atmospheric pressure?
Some common units of measurement for atmospheric pressure include pounds per square inch (psi), inches of mercury (inHg), and millibars (mb). In the scientific community, the preferred unit is pascals (Pa).
  • Mechanics
  • Mechanics
