Atmospheric pressure - questions
In summary: So in your example, the atmospheric force would be directed perpendicular to the surface of the glass because the atmospheric pressure is greater on that side.
Oomph!
55
Hello.
I have two simple questions.
1) I don't understand atmospheric force. I read that it occurs by heaviness of air column and it act perpendicular to any surface.
I can't imagine it. Where is the air column in experiment with glass and papper? Why the atmospheric force act perpendicular to any surface?
2) You have some plastic bottle and you make some holes to it. Than you remove the plug of the bottle. Now you see the springs of watter going on parabole down.
Why? OK, i read if the plug is on the bottle, the atmospheric pressure is bigger than hydrostatic pressure, so watter don't go out from holles. However, if I remove the plug, hydrostatic pressure is bigger. Can you tell me why is bigger now?
Atmospheric pressures are the pressures that the molecules of atmospheric gases exert upon any exposed surface due to molecular impacts with that surface. This pressure (in Pascals per square meter) is the simple product of the molecular flux (in mean number of molecular impacts per square meter per second) and the mean impulse per impact (in Newtons). Pressure equals the molecular flux times the mean molecular impulse.
I don't really understand your other references or questions. I suspect that English is not your first language.
For your 2nd question, the hydrostatic pressure is the same, however when u remove the plug you also have the air from the top of the bottle pressing the water down , so the water at the holes is pushed to go outside by air pressure+hydrostatic pressure and is pushed to stay inside only by the surrounding to bottle air pressure. The difference in those pressures is the hydrostatic pressure which makes the water go out.
For your 1st question, i think what you missing is that pressure is a scalar quantity (pressure doesn't have a direction like a force has, pressure has only magnitude) and the force is equal to the gradient of pressure. The gradient of pressure is a vector quantity.
Related to Atmospheric pressure - questions
1. What is atmospheric pressure?
Atmospheric pressure is the force per unit area exerted by the weight of the Earth's atmosphere. It is commonly measured in units of pressure such as pounds per square inch (psi) or millibars (mb).
2. How is atmospheric pressure measured?
Atmospheric pressure is typically measured using a barometer, which is a device that measures the weight of the atmosphere above a particular point. Other common units of measurement include mercury (Hg) and inches of mercury (inHg).
3. What factors affect atmospheric pressure?
The main factors that affect atmospheric pressure include altitude, temperature, and weather conditions such as high or low pressure systems. As altitude increases, atmospheric pressure decreases due to the thinner air. As temperature increases, atmospheric pressure also increases.
4. How does atmospheric pressure impact weather?
Atmospheric pressure plays a major role in determining weather patterns. High atmospheric pressure typically brings clear, sunny weather while low atmospheric pressure is associated with cloudy, stormy weather. Changes in atmospheric pressure can also indicate the movement of weather systems.
5. How does atmospheric pressure affect human health?
Changes in atmospheric pressure can affect the human body, particularly the respiratory and circulatory systems. High altitude and low atmospheric pressure can cause altitude sickness, while low atmospheric pressure can also worsen existing health conditions such as asthma or heart disease. Extreme changes in atmospheric pressure can also lead to severe weather events that can impact human health.
  • Mechanics
17K
  • Mechanics
