Atmospheric pressure, vacuum, etc.
In summary: You can take a mercury barometer and measure the pressure inside the instrument, or you can take an air pressure gauge and measure the pressure outside the instrument. The mercury barometer is more accurate because it doesn't change with altitude. The air pressure gauge will change with altitude because the pressure of the atmosphere decreases with height.
tomlib
The value of the atmospheric pressure does not seem to me to be correct 1013 HPa and can be recalculated as approx. 1kg/cm2 (is it true?), but it does not seem that such a pressure would be manifested by any resistance or any deformations, for example on a folded sheet of paper. It is possible that this value is derived from the creation of a vacuum. Is possible, that the cause of the great force of vacuum is due to something other than the pressure of the surrounding air, which appears to be normal without resistance? How is it possible that if there is a vacuum in space, the air from the Earth is not drawn into space?
How will the vacuum value actually change in different sized vessels or on different sized surfaces.
Probably not, but it is hard to tell what you mean by this. Pressure is well-understood.
Gravity pulls it down.
Likes berkeman, russ_watters and Vanadium 50
Loosely speaking...
Vacuum is just the absence of air, and it does not "pull". It is really air that "pushes". You don't see the effects of the relatively high "pushing force" of the atmospheric air because for the most part it is counter-balanced (for instance, fluids inside the human body are at the same pressure of external air and won't allow the latter to make us implode).
No.
Occasionally you'll run across a reference to "inches of vacuum" or something like that, but those are actually just offsets of outside pressure, used for convenience.
I would say that the force of the vacuum is greater than the force of gravity.
  • Sad
Likes weirdoguy
You can say it all you want, but the simple fact that we do actually have an atmosphere proves your saying wrong.
Likes russ_watters
Okay, thank you then.
The two do not have the same units. So neither is greater than the other.
The "force of gravity" is in units of force per unit mass. For example, 9.8 Newtons per kilogram. The "force of vacuum" is in units of force per unit area. For example, 100 kiloNewtons per square meter.
If you want to compare the two to one another, you will have to somehow figure out how many kilograms of atmosphere there is in a square column that is 1 meter on each side and is as tall as the atmosphere.
An overly simplistic calculation would assume an atmosphere which has constant density from top to bottom. Let us attempt such a calculation.
Room temperature air at ordinary atmospheric pressure is about 1.293 kilograms per cubic meter. The atmosphere is, let's say, 100 kilometers in height. Our square tower has a volume of 1x1x100000 = 100000 cubic meters. So that is 129300 kilograms. Multiply by the acceleration of gravity (9.8 Newtons per kilogram) and that's roughly 1.3 million Newtons.
The "force of gravity" on one square meter calculated this way is 1.3 million Newtons.
The "force of vacuum" on one square meter is only about one hundred thousand Newtons.
Calculated this way, the "force of gravity" is way larger than the "force of vacuum". Contrary to your supposition.
But of course, the above calculation is wrong, wrong, wrong. Atmospheric pressure decreases as you go up in elevation. Wikipedia goes fairly deep into the details. To a decent approximation, there is an exponential decrease in density with altitude. The constant on the exponential is about 8.4 km for a factor of e (Euler's number, base for natural logs, 2.71828...) reduction.
As a rough rule of thumb, this means that the actual amount of atmosphere over any point on the earth is equivalent to a tower of normal pressure air that is 8.4 km in height. Yes, the same 8.4 km as above -- natural logs are nice for this kind of thing.
Let us do that calculation again. 1.293 kg per cubic meter times 8.4 km height times 9.8 N/kg is roughly 101000 N / m^2 for the "force of gravity"
Conclusion: The force of gravity and the force of vacuum are indeed identical. As they must be according to the mainstream understanding of an atmosphere in static equilibrium under gravity.
Edit: Here is the source for the 8.4 km figure:
https://en.wikipedia.org/wiki/Density_of_air#Variation_with_altitude said:
The pressure can be approximated by another exponent:
{\displaystyle p=p_{0}e^{\left({\frac {gM}{RL}}\right)\ln \left(1-{\frac {Lh}{T_{0}}}\right)}\approx p_{0}e^{-{\frac {gM}{RL}}{\frac {Lh}{T_{0}}}}=p_{0}e^{-{\frac {gMh}{RT_{0}}}}}
Hp is 8.4 km,
##H_p## is the inverse of the ##\frac{gM}{RT_0}## in the formula above.
That's silly. Vacuum is the absence of force (atmospheric pressure).
You've started multiple threads and your tone and approach are very strange. You are arguing against explanations of reality based on incredulity alone. Basically arguing that reality itself is wrong. It makes no sense. Accept that reality is reality and then learn the explanations for it. Asking questions like "I don't understand how..." is fine, but making counterfactual claims is not. It won't help you learn and it is an approach we will not humor indefinitely.
Likes Bystander and Dale
We do get questions like this occasionally, but people tend to overcomplicate it. It's no different from pressure at the bottom of a pool (after subtracting atmospheric pressure), a stack of books on a table or a pile of anything on the ground. For the sake of pressure at the bottom or, roughly, its mass, the atmosphere is just a "pile of air" sitting on the ground.
Likes Chestermiller, berkeman, Bystander and 1 other person
FAQ: Atmospheric pressure, vacuum, etc.
What is atmospheric pressure?
Atmospheric pressure is the force exerted onto a surface by the weight of the air above that surface in the atmosphere of Earth (or that of another planet). It is measured in units such as Pascals (Pa), atmospheres (atm), or millibars (mb). At sea level, the average atmospheric pressure is about 1013.25 mb or 1 atm.
How is a vacuum created?
A vacuum is created by removing air or other gases from a space, resulting in a lower pressure than the surrounding atmosphere. This can be achieved using vacuum pumps, which physically remove gas molecules from a sealed volume, or by creating a space where no air molecules are present, such as in outer space.
Why does atmospheric pressure decrease with altitude?
Atmospheric pressure decreases with altitude because there are fewer air molecules exerting force at higher elevations. As you ascend, the density of the air decreases, leading to a drop in pressure. This is why mountaineers and pilots need to be aware of changing pressure conditions as they go higher.
What are the effects of low atmospheric pressure on the human body?
Low atmospheric pressure can lead to a variety of physiological effects on the human body, including altitude sickness, which is characterized by symptoms such as headaches, nausea, dizziness, and shortness of breath. At very high altitudes, the lower oxygen levels can lead to more severe conditions like high-altitude pulmonary edema (HAPE) or high-altitude cerebral edema (HACE).
How does atmospheric pressure affect weather patterns?
Atmospheric pressure plays a crucial role in weather patterns. High-pressure systems are typically associated with clear, calm weather, while low-pressure systems can lead to clouds, wind, and precipitation. The movement and interaction of these pressure systems drive much of the weather we experience on Earth.
9K
