Atom-Transfer Radical Polymerization: Method Question
In summary, the graduate student is doing ATRP and is having an issue with the polymerization. He thinks it is caused by catalyst poisoning, but does not know how to fix the problem. He attempted to quick-add the monomer and initiator and then froze-pump-thaw three times, but the polymerization still turned green. He then put the polymerization in a heated oil bath and it finally polymerized. He runs all his polymerizations under vacuum. Can anyone tell him what is happening?
Caleb Breaux
Hi everyone,
So I'm a chemical engineering grad student and oddly enough I have been tasked with doing chemistry (strange I know). I'm currently doing atom-transfer radical polymerization (ATRP) using a metal (CuCl or CuBr) and a ligand (dNbpy or PDMETA). My monomer is a methacrylate group with a tert-butyl dimethyl silyl tail on it. Currently, I'm having an issue with my polymerization and I think it's caused by catalyst (CuCl) poisoning, but I was hoping someone here might be able to shed some light on the situation.Current State:
I have CuCl, lightish green so it's oxidized a little bit, but I assume it's no big deal. I place in roughly a 2:1 molar ratio of ligand (dNbpy) and metal (CuCl). I then proceed to put in my monomer and initiator (the initiator is a 1:1 molar ratio with the metal compound). The dNbpy is solid and so is the CuCl, the monomer and initiator being liquids. As soon as the liquids meet with the solids, I get a reddish color that will (over the course of about ten to twenty minutes) go from red, to brown, to green. I know that Cu(II)Cl2 is a green color, so I assume that once it becomes green, the majority of the metal is in its oxidized state. For ATRP, the key (as I understand it) is for propagation to be slow and initiation to be fast. Control is possible through the activation of a radical by the initiator (or halogen capped group) and the Cu(I)Cl reacting to form a radical and Cu(II)Cl2. This is a reversible reaction so assuming that activation and deactivation occur at roughly the same speeds, I'd expect the reaction to be red with all Cu(I)Cl present, brown with a mixture of Cu(I)Cl and Cu(II)Cl2 present, and green when pure Cu(II)Cl2 is present. So I figured my solution, during polymerization, should be brown...however...the solution is green! This makes worried, especially since the polymerization is going 7 times slower than it normally should.
Today I attempted to "very quickly" add the monomer and initiator and then freeze-pump-thaw (I always do this before polymerization) three times before the solution turned green. After three freeze/pump/thaw cycles, I saw no bubbles in the solution and assumed all the oxygen was gone. The solution was still red, and I then placed it in a heated oil bath (75oC) for the polymerization. 15-20 minutes later I checked on the polymerization (it's a bulk polymerization by the way) and the solution was green. I run all my polymerizations under vacuum, rather than over nitrogen or argon.
Can anyone tell me if the color of ATRP-type polymerizations with CuCl is suppose to red, brown, or green during the polymerization? Catalyst poisoning is the only criminal I can think of for my failed reactions.
Chemistry news on Phys.org
Can you furnish any details for the actual reaction mechanism?
https://en.wikipedia.org/wiki/Atom-transfer_radical-polymerization
The reaction mechanism is basically the picture you see at the top of the wikipedia page for ATRP, I'm even using CuCl. In the top reaction you have your initiator (R-Cl) whose bond is cleaved and radical stabilized by the Metal-ligand complex. The radical then proceeds to propagate by continuously attack the vinyl monomers. Every so often though, the metal ligand will reduce, causing a temporary "capping" of the radical. It's this capping that's suppose to allow for overall control over the molecular weight distribution.
Ain't that interesting --- my first reaction would be to "play" with initiator:complex ratios with no monomer present --- do a little colorimetry just to verify your red-brown-green suspicion (which sounds as good a guess as any to me). From there, one or two polymerizations of monomers known to be well-behaved with this method. Then ... ?
FAQ: Atom-Transfer Radical Polymerization: Method Question
What is Atom-Transfer Radical Polymerization (ATRP)?
Atom-Transfer Radical Polymerization (ATRP) is a method used to synthesize polymers with controlled structures and properties. It involves the use of a transition metal catalyst and a halogen-containing compound to control the growth of polymer chains.
What are the advantages of ATRP over other polymerization methods?
Some advantages of ATRP include its ability to produce polymers with controlled molecular weights and narrow molecular weight distributions, as well as the ability to incorporate a variety of functional groups into the polymer chains.
What is the mechanism of ATRP?
The ATRP mechanism involves a reversible activation/deactivation process of the transition metal catalyst, which allows for control over the polymer chain growth. The halogen-containing compound (initiator) also plays a crucial role in this process by initiating the polymerization reaction.
What are the key components needed for ATRP?
The key components needed for ATRP include a transition metal catalyst, a halogen-containing compound (initiator), a monomer, and a solvent. The choice of each component will affect the outcome of the polymerization reaction.
What are some applications of ATRP?
ATRP has a wide range of applications, including the synthesis of functional materials, such as coatings, adhesives, and biomedical polymers. It is also used in the production of specialty polymers with specific properties, such as conducting polymers and block copolymers.
