Atomic Physics, two particle system in 1-d harmonic oscillator
In summary, you have made progress towards solving the problem of obtaining the exchange splitting of the lowest excited energy level of two identical spin 1/2 particles in a one dimensional harmonic oscillator potential. However, you have concerns about the result not seeming very profound and are unsure if your approach is correct. It may be helpful to check your solution against known results and vary the value of W to better understand the behavior of the system.
Newtons Balls
Two identical spin 1/2 particles of mass m exist in a one dimensional harmonic oscillator potential [tex]\frac{kx^{2}}{2}[/tex] where x is the position coordinate and k is a constant. The particles interact with eact other with a potential W[tex]\delta[/tex](x-x'), where [tex]\delta[/tex](x-x') is a Diract delta function of the particle coordinates x and x', and W is a constant. Obtain the exchange splitting of the lowest excited energy level of the system for small W by considering the states to be the triplet and singlet configurations when the particles share the two lowest one-particle spatial states of the system.
Umm there are rather a lot :)
Schrodinger's Equation gives a nasty solution containing a Hermite polynomial... I don't want to type these two into latex.
It gives a known integral of between infinity and minus infinity:
[tex]\int[/tex]y[tex]^{2}[/tex]exp(-ay[tex]^{2}[/tex])dy = 1/2 [tex]\sqrt{\frac{\pi}{a^3}}[/tex]
Well at the moment we're strugging to even start, we can get the wave functions of the individual particles but combining the two into a joint wavefunction is tricky. After that I believe you integrate that multiplied by the given potential which should be in the form of the given integral. The problem is finding the wave function consisting of both the particles.
I don't really need a lot of general help on this, just any advice on how to combine the two wavefunctions of the individual particles into one consisting of both. If you want me to type up the solution for each particle I can but it'd take a lot of time with latex.
Hopefully this makes some sense... we've been looking at this for a few hours with quite limited progress :cry:
Thanks!
Update: I think I've managed to solve this in the end but have doubts.
It resulted in a solution of W(mk)[tex]^{1/4}[/tex]/(2h)[tex]^{1/2}[/tex]
Which is small(?) when W is small, so perhaps I made a mistake as that doesn't seem very profound.
Solution found by using standard wavefunction result for particle in a harmonic oscillator which is a product of hermite polynomials, combined the two by using a slater determinant. Then used an equation I dug up which indicates that the exchange splitting is 2X where X is:
[tex]\int[/tex]phi0(x).phi1(x').phi1(x).phi0(x').P dx dx'
Where P is the potential between the two particles, phi0 and phi1 referring to the wave function in the ground and second state respectively.
Using the given values for the potential and the two wave functions it all came out nicely and was in a form which matched the solution to the given integral which indicates its in the right direction.
It all comes out nicely to the result stated above, but I'm a bit worried about the 'for small W' mentioned in the question doesn't seem to do anything useful...
so I'm not sure its correct.
Any help would be greatly appreciated!
Dear Scientist,
Thank you for sharing your progress on solving this problem. It seems like you have made some good progress, but I can understand your concerns about the result not seeming very profound.
One possible reason for this could be that the given potential W\delta(x-x') is a point interaction, which means that it only affects the particles when they are at the exact same position. This could result in a small interaction between the particles, leading to a small exchange splitting.
To confirm your solution, I would recommend checking it against any known results or equations for exchange splitting in a one-dimensional harmonic oscillator potential. You could also try varying the value of W and see how it affects the exchange splitting to get a better understanding of the behavior of the system.
I hope this helps and good luck with your further analysis!
FAQ: Atomic Physics, two particle system in 1-d harmonic oscillator
What is atomic physics?
Atomic physics is the study of the properties and behavior of atoms, the smallest building blocks of matter. It involves understanding the structure, properties, and interactions of atoms and their constituent particles, such as electrons, protons, and neutrons.
What is a two particle system in 1-d harmonic oscillator?
A two particle system in 1-d harmonic oscillator refers to a simplified model used in atomic physics to study the interactions between two particles in a confined, one-dimensional space. The particles are assumed to be connected by a spring-like force and move back and forth in a harmonic motion.
What is the purpose of studying this system in atomic physics?
The purpose of studying the two particle system in 1-d harmonic oscillator is to gain a better understanding of the fundamental principles of atomic structure and behavior. It allows scientists to explore the dynamics and properties of atoms in a controlled environment, which can then be applied to more complex systems.
How does this system relate to real-life atoms?
While the two particle system in 1-d harmonic oscillator is a simplified model, it provides insights into the behavior of real-life atoms. Many of the fundamental principles and equations used to describe this system can also be applied to more complex atomic systems, allowing scientists to make predictions and understand the behavior of atoms in the real world.
What are some potential applications of studying this system in atomic physics?
The study of the two particle system in 1-d harmonic oscillator has various potential applications in atomic physics. It can help in the development of new materials, understanding chemical reactions, and designing more efficient electronic devices. It can also provide insights into quantum mechanics and contribute to advancements in fields such as quantum computing and nanotechnology.
