Atomic radii of transition elements
In summary, the atomic radii of transition elements remain approximately constant due to the balance between the increase in nuclear charge and increase in screening caused by the extra electron in the atom. The 3d shell, although more energetic, is more penetrating and therefore able to effectively screen the nuclear charge, resulting in a slightly smaller atomic radius.
Pepealej
Hi, my question is regarding atomic radii of transition elements.
When we move to the right of the periodic table (in the region of the transition elements) the atomic number increases, thus there is one more proton in the nucleus and on more electron in the atom. The nuclear charge increases due to the extra proton, but the screening increases too due to the extra electron, which is added to a shell with more penetration. Thus the nuclear effective charge remains (aprox.) constant making the atomic radii constant (aprox.) for transition elements.
My question is, how can the extra electron increase screening if it is added to a more energetic shell (3d is more energetic than 4s)? Because a more energetic shell mean farther away from the nucleus, isn't it?
Chemistry news on Phys.org
The extra electron added to the 3d shell may be further away from the nucleus than the 4s shell, however the 3d shell is more penetrating due to its higher angular momentum. This means that the outer electrons in the 3d shell are able to feel the full effect of the nuclear charge and this helps to screen the nuclear charge better than the 4s shell. Therefore, the extra electron added to the 3d shell increases the screening effect and results in a slightly lower nuclear effective charge, which in turn leads to a smaller atomic radius.
Related to Atomic radii of transition elements
What are transition elements?
Transition elements are elements located in the middle portion of the periodic table, between groups 2 and 13. They are also known as transition metals and have unique properties such as multiple oxidation states, variable atomic radii, and the ability to form colored compounds.
What is atomic radii?
Atomic radii is a measurement of the size of an atom. It is usually defined as the distance from the nucleus to the outermost electron shell. As you move across a period in the periodic table, the atomic radii decreases due to the increase in nuclear charge. However, in transition elements, the atomic radii can vary due to the presence of electrons in different energy levels.
How does atomic radii change across transition elements?
As you move from left to right across the transition elements in the periodic table, the atomic radii slightly decreases. This is due to the increase in nuclear charge and the addition of electrons to the same energy level. However, the atomic radii may also increase in some transition elements due to the presence of electrons in different energy levels and the shielding effect of inner electrons.
What are the factors that affect atomic radii in transition elements?
The main factors that affect atomic radii in transition elements are the number of electrons, nuclear charge, and the shielding effect of inner electrons. The addition of electrons to the same energy level increases the nuclear charge, causing a decrease in atomic radii. However, the presence of electrons in different energy levels and the shielding effect can cause an increase in atomic radii.
Why do transition elements have variable atomic radii?
Transition elements have variable atomic radii due to the presence of electrons in different energy levels. This is because the outermost electrons in transition elements are not confined to a single energy level, unlike other elements in the periodic table. As a result, the atomic radii can vary depending on the energy level of the outermost electrons.
  • Atomic and Condensed Matter
  • Other Physics Topics
