Atoms and energy levels question
In summary, as atoms are brought closer together to form a crystal lattice structure, there is an interaction between them that causes the electrons in a particular shell to have slightly different energy levels from those in the same orbit of an adjacent atom. This results in an expansion of the fixed energy levels of valence electrons, creating a band of allowed energy levels in the material. In the case of molecules, bringing in multiple atoms can create an infinite number of energy levels, and the orbitals are delocalized over the entire molecule rather than being confined to a specific atom.
eis3nheim
As the atoms of a material are brought closer together to form the crystal lattice structure, there is an interaction between atoms, which will result in the electrons of a particular shell of an atom having slightly different energy levels from electrons in the same orbit of an adjoining atom. The result is an expansion of the fixed, discrete energy levels of the valence electrons. In other words, the valence electrons in a silicon material can have varying
energy levels as long as they fall within the band .
Similar to what happens when you bring two H atoms together. The energies of the 1s "orbitals" split into a lower energy "bonding molecular orbital" and a higher energy "antibonding molecular orbital." (Higher and lower are also wrt the energies of the isolated H atoms' 1s energy levels.)
If you bring in three atoms, you get three levels; if you bring in what amounts to infinite atoms, you get an infinity of levels -- essentially a "band" of allowed energies. I wouldn't really say that the levels are confined to one atom or the next. In the molecular case, the "orbitals" are delocalized over both atoms. it doesn't make sense to say that the lower energy level sits on one of the atoms or the other, these are electronic states that are delocalized over the whole molecule.
Would you explain more.
Related to Atoms and energy levels question
1. What are atoms and energy levels?
Atoms are the basic building blocks of matter, composed of a nucleus containing protons and neutrons, surrounded by electrons in energy levels or shells.
2. What determines the number of energy levels an atom has?
The number of energy levels an atom has is determined by the number of electrons it has. Each energy level can hold a specific number of electrons, with the first level holding a maximum of 2 electrons, the second level holding a maximum of 8 electrons, and so on.
3. How do energy levels relate to an atom's stability?
An atom's stability is determined by the arrangement of its electrons in the energy levels. When an atom's outermost energy level is full, it is considered stable. Atoms will gain, lose, or share electrons in order to achieve a full outermost energy level and become stable.
4. Can energy levels change in an atom?
Yes, energy levels can change in an atom through the absorption or emission of energy. When an atom absorbs energy, its electrons can jump to a higher energy level. When the electrons release that energy, they fall back to their original energy level. This process is called electron excitation and de-excitation.
5. How are energy levels represented in an atom's electron configuration?
Energy levels are represented in an atom's electron configuration by the numbers and letters that indicate the number of electrons in each energy level. For example, the electron configuration of carbon is 1s2 2s2 2p2, meaning it has 2 electrons in the first energy level, and 4 electrons in the second energy level (2 in the 2s sublevel and 2 in the 2p sublevel).
  • Atomic and Condensed Matter
12K
