Atoms as spheres in packing fraction of crystal lattice
In summary, atoms are considered to be spheres because it is the simplest and most intuitive model. The data on crystal structures can be compared using this model.
spaghetti3451
1,344
34
Why are atoms taken to be spheres, and not of some other shape, in the calculation of the packing fraction of different crystal lattices?
In other words, what experimental evidence and theoretical reasoning motivates this form of the atomic shape?
Firstly.. i consider we cannot give atoms any shape due to uncertainty principle.
Earlier, Atoms were considered to be spherical because orbits of last electron was considered to be spherical. but we have to rule that out since there is no definite path for electron. It has been replaced by the statements of probability which is dictated by the wave functions of the last electron.
This is the sum total of the views I've gathered from the internet:
Atom is described spherical in shape just for the sake of simplicity. It's very similar to (not the same as) a group of honey bees (electrons) swarming over a flower (nucleus). The truth is that you can only assign a probability density function for the positions of the electrons around the nucleus, which is in turn based on the solution of the Schrodinger equation for the Coulombic potential under consideration. These give rise to various so-called orbitals which delimit the region in which ##95\%## of an infinite set of measurements of the positions of the electrons is likely to provide. The "shape" of the atom is determined by this outer boundary. :biggrin:
Now, having precisely defined the meaning of "the shape of an atom", we can rigorously state when an atom is indeed "spherical": :wink:
Most atoms, when they are free (and of course most elements are not found as free atoms in nature), are not spherical. The conditions for an atom to be spherical are any of the following:
  • The atom has electrons only in the s orbitals.
  • The atom has the sub-shell of its largest principal quantum number either half-filled or full-filled (Unsold's Theorem).
That does not, in any way, make it clear why atoms are considered to be spheres in the calculation of packing fractions. I guess it's only because the spherical shape is the simplest and most intuitive model of an atom. o0)
yes you are right... makes sense
Just wanted to put in my two cents on this one, given that I've looked into the topic before.
What it really comes down to is the need of Materials Engineers and Scientists to compare values such as mass-density or line-density at the atomic scale. The lengths are generally large enough that we don't need to worry about detailed modeling of the orbitals, so we approximate the outermost electrons as spheres. This allows the massive amount of data on crystal structures to be comparable because it's all using the same, generally accurate method.
I'd also point out that methods like X-Ray Diffraction are actually looking at the internuclear distance, and do not involve any interaction with the electron lattice. These positions are essentially fixed, down to the picometer; materials scientists generally don't care about the resultingly small uncertainty in the location of the lattice points.
This is an old model of course, but it works quite well for modelling the mechanical and thermodynamic properties of materials. If you're interested, one of my favorite youtube videos shows Dr. Bragg himself explaining dislocations by way of the sphere model. With bubbles.
FAQ: Atoms as spheres in packing fraction of crystal lattice
What is the concept of atoms as spheres in the packing fraction of a crystal lattice?
The concept of atoms as spheres in the packing fraction of a crystal lattice refers to the arrangement of atoms in a crystal structure. It is based on the idea that atoms can be thought of as hard spheres that are packed together in a regular and orderly manner to form a crystal lattice.
How is the packing fraction of a crystal lattice calculated?
The packing fraction of a crystal lattice is calculated by dividing the volume of the atoms in the unit cell by the total volume of the unit cell. This value is then multiplied by 100 to get a percentage.
What is the significance of the packing fraction in crystal structures?
The packing fraction is important in crystal structures because it determines the density and stability of the crystal. A higher packing fraction means there are more atoms packed closely together, resulting in a denser and more stable crystal structure.
How does the packing fraction vary in different crystal structures?
The packing fraction can vary greatly in different crystal structures, depending on the type and size of atoms present. For example, close-packed structures such as face-centered cubic have a higher packing fraction compared to less dense structures like body-centered cubic.
Can the packing fraction of a crystal lattice be changed?
Yes, the packing fraction of a crystal lattice can be changed by altering the size or arrangement of the atoms within the lattice. This can be achieved through processes such as alloying, doping, or applying pressure to the crystal.
