Atoms in a solid - Calculating Distances and Cohesive Energy
In summary: In this particular case, that means the distance between the atoms is equal to the radius of a square with sides a_0.
TFM
1,026
Consider two different two-dimensional arrangements, (a) and (b), of four atoms (just four!) defined as follows:
(a) in which the centres of the four atoms form a square of side [tex] a_0 [/tex]
(b) in which the centres of the atoms form an equilateral diamond shape with angles 60° and 120°, and with the length of the side being [tex]b_0[/tex]
If the inter-atomic interaction potential is of the Lennard-Jones form [tex]U(r) = 4\epsilon [(\frac{\sigma}{r})^{12} - (\frac{\sigma}{r})^6][/tex]
and you neglect next nearest neighbours, calculate:
(i) the nearest neighbour distances [tex]a_0[/tex] and [tex]b_0[/tex], respectively
(ii) the cohesive energy per atom of each arrangement
Hence deduce which of the two arrangements would be favoured energetically at very low temperature. Would taking the next nearest neighbours change this conclusion?
Lennerd-Jones Equation given
Hi,
I am not quite sure what to do for this question.
For the first part, I am thinking that the atoms are joined together, so a0 would be one atomic diameter, for B0), it would require some trigonometry to get the length
Does this make sense?
Thanks,
TFM
What do you mean be "one atomic diameter"?
What is special about the potential energy of a system in static equilibrium?
Work out the potential energy of systems (a) and (b) as a function of distance between adjacent atoms, d. What value of d will correspond to equilibrium?
Well For the square, i am assuming the atoms are touching so if a0 is the distance form the center of each atom, it would equal the length of one atom.
The potential energy of a system in static equilibrium is a minima, thus = 0 when you differentiate.
I'm not sure if you've solved the problem yet, but I'll just make sure you're on the right path.
There is no such thing as the "length of one atom" (other than an order of magnitude estimate), for a couple of reasons. Firstly atoms kind of spread out everywhere and we can't do much more than say "68% of the time an atom will be at most this large". But that only applies to isolated atoms; when we put other atoms around (like we do here) the size and shape of the atom will change.
Even if the atoms had definite size the distance between them wouldn't necessarily depend on their size (think of planets; the distance between planets and the sun doesn't depend on the radius of the planet). So how can we find the distance between the atoms?
"The potential energy of a system in static equilibrium is a minima, thus = 0 when you differentiate."
That hits the nail on the head! All you need to do is find the distance corresponding to minimum potential energy.
Related to Atoms in a solid - Calculating Distances and Cohesive Energy
1. What is an atom in a solid?
An atom in a solid is a fundamental unit of matter that is tightly bound with other atoms in a fixed arrangement, forming a solid material. It is the smallest unit of a solid that still retains the properties of that material.
2. How is the distance between atoms in a solid calculated?
The distance between atoms in a solid can be calculated by dividing the length of the solid's unit cell by the number of atoms present along that length. This gives the average distance between neighboring atoms in the solid.
3. What is cohesive energy?
Cohesive energy is the amount of energy required to separate the atoms in a solid material and turn it into individual atoms. It is a measure of the strength of the bonds between atoms in a solid.
4. How is cohesive energy calculated?
Cohesive energy can be calculated by subtracting the total energy of the separated atoms from the total energy of the solid material. This difference represents the energy required to break the bonds between atoms and is a measure of cohesive energy.
5. What factors affect the cohesive energy of a solid?
The cohesive energy of a solid is affected by factors such as the type of atoms present, the distance between atoms, and the strength of the bonds between atoms. It can also be influenced by external factors such as temperature, pressure, and the presence of impurities in the solid.
  • Atomic and Condensed Matter
10K
