Nusc
- 760
- 2
Now if I want to attach my mathematica notebook to the pdf what would I have to enter in LaTeX?
Crosson said:The Mathematica front end is far and a way the best WYSIWYG editor for LaTeX.
Damning with faint praise if ever I heard it.
It is just a cliche. I think you're reading to much into it.
As it is I find any wisywig for LaTeX that I've tried to be a horrendously pointless thing.
I can't think of many mathematicians I know who use anything like WinEdt. If you're just using WinEdt as a text editor, then what's so special about WinEdt?
To attach your mathematica notebook to a pdf, you can use the "Save As" function in Mathematica. Choose the pdf format and check the box that says "Include Mathematica notebook". This will attach your notebook to the pdf file.
Yes, you can attach multiple mathematica notebooks to a single pdf by using the "Save As" function and selecting all the notebooks you want to include. Each notebook will be added as a separate section in the pdf file.
Yes, you can attach a mathematica notebook to an existing pdf by using the "Append" function in Adobe Acrobat. This will add the notebook as a new section at the end of the pdf file.
No, the attached mathematica notebook will not be editable in the pdf. It will be added as a static document, but you can still open and edit the original notebook in Mathematica.
Yes, you can remove the attached mathematica notebook from the pdf by using the "Remove" function in Adobe Acrobat. This will delete the notebook section from the pdf file.
