Attempts to promote theories which have been superseded
  • Thread starter JohnNemo
In summary, the forum guidelines state that we generally don't allow discussions of discredited or superseded theories, but there is a forum entitled Classical Mechanics in which Newtonian mechanics is discussed as if it is true (i.e. not purely in a historical context). This special treatment of Classical Mechanics is given because Classical Mechanics was discredited/superseded about 100 years ago at about the same time as Lorentz ether theory.
JohnNemo
100
In the forum guidelines
https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/
it states that
'Generally, in the forums we do not allow the following... Attempts to promote or resuscitate theories that have been discredited or superseded (e.g. Lorentz ether theory); this does not exclude discussion of those theories in a purely historical context'
However there is a forum entitled Classical Mechanics in which Newtonian mechanics is discussed as if it is true (i.e. not purely in a historical context). What is the rationale for this special treatment of Classical Mechanics given that Classical Mechanics was discredited/superseded about 100 years ago at about the same time as Lorentz ether theory?
Likes dextercioby
Classical mechanics was not discredited or superseded as far as I know. Newtonian gravity has been superseded, but since it's so overwhelmingly simpler than General Relativity and accurate enough for almost all purposes, we still teach and use it. The same is true for classical electromagnetism, which is much simpler than its quantum counterpart and accurate enough for everyday use.
Theories like Lorentz Ether Theory are not widely used and often aren't as simple or as accurate as the theories we actually use, so we don't discuss them except in historical contexts.
Likes Dale
The rules also say:
Acceptable Sources:
Generally, discussion topics should be traceable to standard textbooks ...
As far as I know, Newtonian gravity and classical electromagnetism are still taught in undergrad college courses from standard textbooks.
Likes Dale, ComplexVar89 and berkeman
They're also incredibly useful, even if you want to think of them as approximations to relativity and/or quantum. In a huge range of circumstances you sacrifice a ridiculously tiny bit of precision for vastly simpler maths.
The same is not true of things like the Lorentz ether. Its results are indistinguishable from relativity, and its maths is identical. It just adds philosophical baggage.
Likes Dale, Vanadium 50 and dlgoff
No, it wasn't. It was extended--more comprehensive theories (general relativity and quantum mechanics) were developed, and classical mechanics was shown to be a valid approximation to those theories under appropriate conditions. That is not true of, e.g., Lorentz ether theory.
Likes TeethWhitener, Dale and QuantumQuest
There's a popular perception, to some extent fed by popular but historically wrong descriptions of Einstein "revolutionizing" or "overthrowing the foundations" of classical physics, that classical physics has been discredited or superseded. It hasn't. A solid understanding of Newtonian mechanics is the essential base on which modern physics is built - this is why the first year of an undergraduate physics major is devoted to classical physics, with special relativity taught as a natural extension.
Likes DennisN, Dale and QuantumQuest
You can't design an aircraft, for example, using QM and GR. You need classical mechanics.
You'd better run out of whatever building you're in, because it is built based on the classical mechanics of Newton's laws. And try not to go over any bridges either.
Zz.
Likes lekh2003, PetSounds, DennisN and 3 others
Zz.
Perfect way to close this out!
Related to Attempts to promote theories which have been superseded
1. What does it mean for a theory to be "superseded"?
When a theory is superseded, it means that a new theory has been developed which better explains a phenomenon or set of observations. This new theory has been accepted by the scientific community and is considered more accurate and comprehensive than the previous theory.
2. How do scientists determine when a theory has been superseded?
Scientists determine when a theory has been superseded through a combination of new evidence and experimentation. As new data becomes available, scientists may discover that the current theory cannot fully explain the observations. This prompts the development of a new theory that better fits the data and can make more accurate predictions.
3. Why is it important to promote theories that have been superseded?
Promoting theories that have been superseded is important because it allows for the growth and advancement of scientific knowledge. By acknowledging and promoting newer, more accurate theories, scientists can continue to refine their understanding of the natural world and make progress in their fields of study.
4. How can promoting superseded theories lead to scientific progress?
Promoting superseded theories can lead to scientific progress by encouraging further research and experimentation. Scientists may use the previous theory as a starting point and build upon it to develop a more comprehensive understanding of the phenomenon. Additionally, promoting superseded theories can also lead to the discovery of new evidence that may support or contradict the newer theory.
5. Are there any drawbacks to promoting theories that have been superseded?
One potential drawback to promoting theories that have been superseded is the confusion it can cause among the general public. If a newer theory is not widely accepted or understood, promoting a superseded theory may create conflicting information and misunderstandings. It is important for scientists to clearly communicate the reasons for promoting a superseded theory in order to avoid confusion and promote accurate scientific knowledge.
  • Feedback and Announcements
  • Quantum Interpretations and Foundations
12K
  • Beyond the Standard Models
  • Sticky
  • Earth Sciences
14K
