Attraction and repulsion of plates in capacitors
In summary: The field E between the plates increases when d decreases because V = Ed is constant. So the force between the plates increases. Whether that brings the plates closer depends on the forces keeping them apart.
hokhani
483
If we make far away the two plates of an ideal parallel -plate-capacitor, which are connected to a battery, the stored energy decreased according to the energy consideration because capacity decreases while the voltage between the two plates is unchanged. Therefore, according to the energy considerations, the two plates like to go farther away towards the lower energy while on the other hand, they have opposite charge and we expect that they attract each other! Could anyone please tell me what practically happens if we release the two plates and why?
It would depend on a lot of factors, such as the voltage and how far apart the plates were and when you released them. Generally a capacitor will have either a physical structure that keeps the plates apart (air in-between as the dielectric) or a solid material dielectric that keeps the plates apart and insulated from each other. Otherwise, the plates would move toward each other and short circuit when they touched.
AM
AM
Consider air as the dielectric between the two plates which are connected to a battery. with the consideration of energy, as I previously pointed, how the plates may become closer while the energy increases?
The battery is supplying energy to the capacitor. If you disconnect the battery with the plates holding charge Q, the voltage, and therefore the potential energy QV, will decrease as the distance between the plates is decreased. This is because the field E being constant, potential (V) decreases with distance. If you keep the battery connected, V remains constant (V=potential energy per unit charge = Ed) so as the separation decreases, the field and, therefore, plate charge increases. So the total energy (QV) increases. That energy is drawn from the battery.
AM
Likes trurle and anorlunda
AM
Thanks. If you consider the battery and capacitor as one system, as a whole, and considering the fact that the systems like to go towards the lower energy potential, the plates like to become closer. To keep the plates in place, we would consume energy.
My question still remains:
We expect the two opposite-charged plates to attract each other while when the plates are connected to the battery, they like to become more separated!
No energy is required to keep the charged plates in place. A force is required to keep them apart but this force does no work. However, if you move the plates closer together, the battery will act to increase the charge on the plates to maintain the potential energy per unit charge of the plate charges.
This is not correct. The force between the plates is always attractive. With no battery keeping V constant, the force of attraction does not change as the plate separation changes. With the battery connected, the force of attraction between the plates increases the closer they get.
AM
AM
Please check if I have got your reasoning correctly:
You mean that in the presence of the battery, when the two plates are closer, the increase of the energy stored in the capacitor is along with more battery consumption. So, the battery causes the two plates become closer.
AM
Related to Attraction and repulsion of plates in capacitors
1. What causes the attraction and repulsion of plates in capacitors?
The attraction and repulsion of plates in capacitors is caused by the presence of opposite charges on each plate. When a voltage is applied to the capacitor, one plate becomes positively charged while the other becomes negatively charged. This results in an electrostatic force of attraction between the opposite charges on the plates.
2. How does the distance between plates affect the attraction and repulsion in capacitors?
The distance between plates directly affects the strength of the attraction and repulsion in capacitors. The closer the plates are, the stronger the electrostatic force between them. This is because the electric field between the plates is stronger when they are closer together, resulting in a stronger force of attraction or repulsion.
3. Can attraction and repulsion occur between plates that have the same charge?
No, attraction and repulsion can only occur between plates that have opposite charges. Like charges repel each other, so plates with the same charge will experience a force of repulsion, not attraction.
4. How does the size of the plates affect the attraction and repulsion in capacitors?
The size of the plates does not have a direct effect on the attraction and repulsion in capacitors. However, larger plates tend to have a larger surface area, which can result in a higher capacitance. This means that for a given voltage, larger plates will store more charge, resulting in a stronger force of attraction or repulsion.
5. What is the role of the dielectric material in attraction and repulsion of plates in capacitors?
The dielectric material in capacitors plays a role in reducing the strength of the electric field between the plates. This results in a lower capacitance and a weaker force of attraction or repulsion. However, the dielectric material also helps to increase the maximum voltage that the capacitor can withstand before breaking down, making it an important component in the design of capacitors.
  • Electromagnetism
  • Electromagnetism
