Attraction between two Hydrogen Atoms
In summary, the main force causing two hydrogen atoms separated by 3 Angstroms to move closer towards each other is electromagnetic, specifically electrostatic effects according to the Heitler-London (QM) model. As the atoms get closer, other forces such as van der Waals may also play a role in attraction. Magnetic forces are generally unimportant in this interaction. At a distance of 1 Angstrom, the electron clouds start to overlap and Coulomb attraction leads to the formation of a molecule, but the detailed models for this are complex.
Buckeye
165
For two hydrogen atoms separated by 3 Angstroms, what is the main force (cause) for the two atoms to move closer toward each other?
As the atoms get closer, does a different force (cause) dominant the original force that started the attraction?
Likes JDoolin
In general, at the atomic or molecular level, the force involved is electromagnetic. The nuclear forces operate only inside the nucleus, while gravity is far too weak to be meaningful for things (atoms and molecules) that are that small.
Can you give a reference for the attractive force of two hydrogen atoms at this distance please?
Thanks,
Ryan
Buckeye said:
For two hydrogen atoms separated by 3 Angstroms, what is the main force (cause) for the two atoms to move closer toward each other?As the atoms get closer, does a different force (cause) dominant the original force that started the attraction?
Perhaps the van der Waals force ?--which is discussed by Bohm (1951) "Quantum Theory". On pp 477-479 Bohm presents a wave function that "corresponds to a statistical tendency to oscillate in phase, for which both classically and quantum-mechanically the systems are found to attract..." and ..."thus the closer the atoms get the more transfer of energy between the atoms"..."if they oscillate in phase they will attract". The QM equations for this attractive interaction for hydrogen atoms are presented by Pauling & Wilson (1935) "Introduction to Quantum Mechanics..." on page 384 in the section titled " Van der Waals Forces for hydrogen atoms".
Thanks,
Ryan
p 544 of "Fundamentals of Atomic Physics" by A. P. Arya published in 1971 by Allyn and Bacon which references Kolos, W. and C.C.J. Roothons, "Revs. Mod. Phys." Vol 32, p 219 (1960).
At 3 angstroms the energy value is negative (-) 0.3 eV roughly by the eyeball.
The cause of the attraction appears to be electrostatic in accordance with the Heitler-London (QM) model of the hydrogen atom. Based on the number of repulsive states (3) vs attractive states (1) the two atoms have roughly a 25% chance of bonding.
I'm interested to learn about the magnetic factors that must also exist. Thanks.
Likes JDoolin
Can someone else add a bit of enlightment?
Thanks!
Magnetic forces are generally unimportant for the attraction between 2 H atoms. In H energy levels, they lead to fine and hyperfine splitting, which is about 100-10,000 times smaller than the electrostatic effects. At 3 A, the two atoms probably have a dipole-dipole force like van der Waals, or some of the more detailed models mentioned above. When the atoms get within about 1 A of each other, the electron clouds start to overlap and there is then Coulomb attraction of one proton with the other atom's electron, which leads to a molecule. Detailed models for this are very complicated.
Likes JDoolin
Related to Attraction between two Hydrogen Atoms
1. What is the nature of the attraction between two hydrogen atoms?
The attraction between two hydrogen atoms is known as a chemical bond, specifically a covalent bond. This means that the two atoms share a pair of electrons, resulting in a stable and strong bond between them.
2. How does the attraction between two hydrogen atoms occur?
The attraction between two hydrogen atoms occurs due to the difference in their electronegativity values. Hydrogen has a relatively low electronegativity, meaning it has a strong tendency to lose its electron and become positively charged. This creates a partial positive charge on one hydrogen atom, which then attracts the partial negative charge on the other hydrogen atom, resulting in an overall attraction between the two atoms.
3. What factors affect the strength of the attraction between two hydrogen atoms?
The strength of the attraction between two hydrogen atoms is affected by the distance between the two atoms, as well as the number and arrangement of their shared electrons. The closer the two atoms are, the stronger the attraction will be. Additionally, if the two atoms have more shared electrons, the bond will be stronger.
4. What is the bond length between two hydrogen atoms?
The bond length between two hydrogen atoms is approximately 74 picometers (pm), or 0.074 nanometers (nm). This distance is the optimal distance at which the attraction between the two atoms is strongest.
5. Can the attraction between two hydrogen atoms be broken?
Yes, the attraction between two hydrogen atoms can be broken through various chemical reactions or physical processes. For example, introducing a stronger electronegative element can disrupt the balance of charge between the two hydrogen atoms and break the bond. Additionally, high temperatures or pressures can also weaken or break the bond between the two atoms.
