kchurchi
- 39
An atwood machince has a m1 = 4.92-kg block resting on a frictionless horizontal ledge. This block is attached to a string that passes over a pulley, and the other end of the string is attached to a hanging m2 = 2.46-kg block.
The pulley is a uniform disk of radius 8.06 cm and mass 0.615 kg. Calculate the speed of the m2 = 2.46-kg block after it is released from rest and falls a distance of 2.67 m.
Work = ∫F dot ds
ΔE = ΔKE(translation) = 1/2*m2*vf^2 - 1/2*m2*vi^2
At first I assumed only the weight force was doing work on mass 2 but I got the wrong answer. Then I thought perhaps tension was also doing work on mass 2. In order to find the tension force, I need to find the torques acting on the pulley and the sum of the forces acting on mass 1. I can do all of this, however, I would like to know if there is an easier, less complex way to do this problem.
Thanks!
