Atwood Machine: Forces & Motion True/False Quiz
In summary, the problem involves a frictionless, massless pulley attached to the ceiling in a gravity field. The center-of-mass of Mb and Ma will accelerate, with Ty being less than (Mb)g and Tz being equal to (Ma)g + (Mb)g. Tx+Ty will also be equal to Tz, and the magnitude of the acceleration of Mb will be equal to that of Ma. Finally, Tx will be equal to Ty. The equation F = ma is relevant in determining the acceleration of the masses. The provided answers for the tries were incorrect for various reasons and may have been chosen based on assumptions or misinterpretations of the problem.
huybinhs
230
A frictionless, massless pulley is attached to the ceiling, in a gravity field g = 9.81 m/s2. Mass Mb is greater than mass Ma. The tensions Tx,Ty, Tz, and the constant g are magnitudes. (Select a response for each statement.)
Please look at this pic:
http://i995.photobucket.com/albums/af79/huybinhs/atwoodmachine.png
Choices:
Greater than; Less than; Equal to; True or False.
The center-of-mass of Mb and Ma accelerates.
Ty is ... (Mb)g.
Tz is ... (Ma)g + (Mb)g.
Tx+Ty is ... Tz.
The magnitude of the acceleration of Mb is ... that of Ma.
Tx is ... Ty.
F = ma
1 Incorrect. (Try 1)
True
Less than
Equal to
Equal to
Equal to
Equal to
2 Incorrect. (Try 2)
True
Less than
Greater than
Equal to
Equal to
Equal to
3 Incorrect. (Try 3)
True
Less than
Greater than
Less than
Equal to
Equal to
4 Incorrect. (Try 4)
False
Less than
Greater than
Less than
Equal to
Equal to
5 Incorrect. (Try 5)
False
Less than
Equal to
Equal to
Equal to
Equal to
6 Incorrect. (Try 6)
False
Less than
Equal to
Greater than
Equal to
Equal to
What is your thinking about answering these questions? Why did you give these particular answers to these tries? How do you think the "Relevant Equation" F = ma applies to all this?
Hey Binh,
Did you figure this one out yet? I have racked my brain and researched, but no luck and I've already used 8 tries...
Related to Atwood Machine: Forces & Motion True/False Quiz
What is the Atwood Machine?
The Atwood Machine is a simple mechanical device used to demonstrate the principles of forces and motion. It consists of two masses connected by a string passing over a pulley.
What is the purpose of the Atwood Machine?
The Atwood Machine is used to study the relationship between forces, masses, and acceleration. It helps to illustrate concepts like Newton's laws of motion and the effects of different forces on an object.
What is the difference between the true and false statements in the quiz?
The true statements in the quiz are based on scientific principles and are supported by evidence and experiments. The false statements are either not supported by evidence or are contradictory to established scientific laws.
Do the masses in the Atwood Machine affect its acceleration?
Yes, the masses in the Atwood Machine affect its acceleration. The larger the mass, the more force is required to move it and the slower the acceleration will be.
Can the Atwood Machine be used to calculate the acceleration due to gravity?
Yes, the Atwood Machine can be used to calculate the acceleration due to gravity. By measuring the masses and acceleration, and using Newton's second law of motion, the acceleration due to gravity can be determined.
