Atwood machine mass accleration problem
In summary, the problem is asking for the acceleration of three masses in a system where a light pulley rotates freely and is fixed in a horizontal position. Two masses, 4m and m, are attached to a string passing over the pulley. The third mass, 4m, is attached to a second string passing over a second massless pulley. Four force equations can be written for the two physical systems in this problem, but the equations provided do not account for all the forces present. Therefore, the stated accelerations cannot be correct.
Benzoate
422
A light pulley can rotate freely about its axis of symmetry which is fixed in a horizontal position. A massless inextensible string passes over a pulley . At one end the string carries a mass 4m, while the other end supports a second massless pulley. A second string passes over the pulley and carries masses m and 4m at its ends. The whole system undergoes planar motion with masses moving vertically. find the acceleration of each of those masses.
Newton's second Law of motion, F(net)=m*a
The problem tells me I have to find the acceleration of 3 masses, two of which are attached to the second pulley.
There are Two physical systems I want to concentrate on containing four force equations I want to write outs: The first physical system will focus on the Atwood machine where the two ends of a string hold the 4m mass and the mass less atwood machine. The second physical system will include the massless pulley at the end of the string containing the first pulley. there will be force equations for the m and 4m masses, both of which are attached at the two ends of the string containing the massless pulley. Therefore, I should have a total of four force equations.
Atwood machine where there is a 4m mass and massless pulley attached to the ends of each string:
T-4*mg=4m*dv/dt; -T+m*g=m*dv/dt
since the pulley is massless, m= 0 and therefore T=0 and therefore dv/dt=0, which cannot be right since the problem states that the the whole systems undergoes planar motion and therefore the system must have some acceleration.
Atwood machine containing masses m and 4m.
4mg-T'=4*m*dv'/dt, T-mg=m*dv'/dt
Therefore, dv'/dt= g, which isn't right because if the acceleration of the all 3 masses were just g, the masses wouldn't have any tension
Atwood machine where the 4m and m
"Atwood machine where there is a 4m mass and massless pulley attached to the ends of each string:
since the pulley is massless, m= 0 and therefore T=0 and therefore dv/dt=0, which cannot be right since the problem states that the the whole systems undergoes planar motion and therefore the system must have some acceleration."
If your 1st system (free body diagram) is as you describe, there are two forces you have omitted in your equation: the two tension forces applied to the 2nd massless pulley by the second string supporting the m and 4m masses at its end.
Related to Atwood machine mass accleration problem
What is an Atwood machine mass acceleration problem?
An Atwood machine mass acceleration problem is a physics problem that involves a pulley system with two masses connected by a string. The goal of the problem is to determine the acceleration of the masses and the tension in the string.
What are the basic principles involved in solving an Atwood machine mass acceleration problem?
The basic principles involved in solving an Atwood machine mass acceleration problem are Newton's laws of motion, specifically the laws of inertia, force, and action-reaction. These laws state that the net force on an object is equal to its mass times its acceleration, and that for every action, there is an equal and opposite reaction.
What are the steps to solve an Atwood machine mass acceleration problem?
The steps to solve an Atwood machine mass acceleration problem are as follows: 1. Draw a diagram of the system, labeling the masses and the pulley. 2. Identify the forces acting on each mass, including tension, weight, and normal force. 3. Write down Newton's second law for each mass, setting the net force equal to mass times acceleration. 4. Use the relationship between the two masses and the tension to eliminate one of the variables. 5. Solve the resulting equations to find the acceleration and tension in the system.
What are some common mistakes to avoid when solving an Atwood machine mass acceleration problem?
Some common mistakes to avoid when solving an Atwood machine mass acceleration problem include: - Not considering the pulley's mass and its effect on the system - Not correctly identifying the forces acting on each mass - Not using the correct signs for the forces in the equations - Not properly setting up and solving the equations to eliminate a variable - Not double-checking the units and making sure they are consistent.
How can understanding Atwood machine mass acceleration problems be useful?
Understanding Atwood machine mass acceleration problems can be useful in many ways, such as: - Improving problem-solving skills - Strengthening understanding of Newton's laws of motion - Preparing for physics exams and tests - Applying concepts to real-world situations, such as analyzing the motion of elevators or cranes - Enhancing critical thinking skills by breaking down a complex system into simpler parts.
9K
