Atypical definition of decreasing function
In summary, In the conversation, the first person discusses a "strange" definition of a decreasing function they saw on the web a few days ago, but can no longer find. The definition involved three relationships and showed that one implies another. The second person asks about determining if a given function, which is not a polynomial, is periodic or not. They mention a principle they have heard about odd-degree polynomials not being periodic, and wonder if this applies to their function. The third person clarifies that the term is "periodic" and not "periodical," and explains the general method for determining the period of a function. They suggest writing f(x) = f(x+L) and solving for L, and if L is
rahl__
1 few days ago i saw a "strange" definition of a decreasing function in the web, but i can't find it now. there were three relationships, and when showing that one implies another, you could tell that the function is decreasing. one relationship looked like this:
[tex]f(x)=\frac{1}{x}[/tex]
does it look familiar?
2 there is a function:
[tex]f(x)=\frac{2x+cos {x}}{3+x^{2}}[/tex]
how can find if it is periodic[al?]? I've heard that the polynomial of an odd degree is not periodic[al], can I use this principle to define whether that function is periodic[al] or not? does this principle say[tell? sorry for this ungrammatical statement], that there are some polynomials of an even degree that are periodic[al]?
3 is it spelt periodic or periodical? ;/
Mathematics news on Phys.org
2 What you have here is not a polynomial. It's not even a quotient of polynomials. The general idea when trying to get determinethe period (if it exists) of a function is simply to write f(x) = f(x+L) and solve for L. If L is of the form kP (k integer), then P is your period.
The definition of a decreasing function may vary depending on the source, so it is possible that the definition you saw was not the traditional one. It is important to always refer to reliable sources when looking for mathematical definitions and concepts.
Regarding the given function f(x)=\frac{1}{x}, it is indeed a decreasing function as the value of the function decreases as x increases. This can be seen from the fact that as x increases, the denominator also increases, causing the overall value of the function to decrease.
For the second question, to determine if a function is periodic, you can check if it repeats itself after a certain interval. In the case of f(x)=\frac{2x+cos {x}}{3+x^{2}}, it is not a periodic function as it does not repeat itself after a specific interval. The principle you mentioned regarding polynomials of odd degree not being periodic is correct. However, there are also polynomials of even degree that are not periodic, so it is not a definitive rule to determine periodicity.
Lastly, the correct spelling is "periodic." "Periodical" can also be used, but it is less commonly used in mathematics.
Related to Atypical definition of decreasing function
What is an atypical definition of a decreasing function?
An atypical definition of a decreasing function is one where the output values decrease as the input values increase. This is the opposite of the typical definition of a decreasing function, where the output values decrease as the input values decrease.
Can a function be both increasing and decreasing?
No, a function cannot be both increasing and decreasing at the same time. This would defy the definition of a decreasing function, where the output values must consistently decrease as the input values increase.
What are some examples of atypical decreasing functions?
Some examples of atypical decreasing functions include logarithmic functions, where the output decreases as the input increases; and exponential decay functions, where the output decreases at a decreasing rate as the input increases.
How do you graph an atypical decreasing function?
The graph of an atypical decreasing function will show a downward trend, with the output values decreasing as the input values increase. However, the shape of the graph may vary depending on the specific function being graphed.
Why is it important to understand atypical definitions of functions?
Understanding atypical definitions of functions allows for a deeper understanding of mathematical concepts and can help in problem-solving and critical thinking. It also broadens the scope of functions that can be used in real-world applications.
