Au-196 decay: help reading tables
In summary, the conversation discusses the process of Au-196 going to Hg-196 through a nuclear reaction. The confusion arises from the spin numbers in the tables for both isotopes and how the electron and neutrino carry away some specific orbital angular momentum. The +/- signs in front of the spin numbers indicate parity, and the reaction involving electron capture would require the electron to have at least ~4.4MeV of energy. However, in most cases, the electron would have an energy in the low keV range.
JustinLevy
895
I'm sorry, this is probably a pretty stupid question as I probably am just not understanding something basic about nuclear reactions. Can someone please help?
I am trying to understand what happens when Au-196 goes to Hg-196.
I am assuming it is something like:
[itex]Au^{196}_{79} \rightarrow Hg^{196}_{80} + e^- + \bar{\nu}_e + 0.686 MeV[/itex]
according to this table:
http://atom.kaeri.re.kr/cgi-bin/nuclide?nuc=Au196
What is confusing me is that it says the Au isotope is spin 2, and the table for Hg says the isotope is spin 0.
http://atom.kaeri.re.kr/cgi-bin/nuclide?nuc=Hg196
How is this possible?
Somehow the electron and neutrino must carry away some specific orbital angular momentum?
Also, what is the +/- they use in front of the spin numbers. How would a +2 be different than a -2?If I was to look at an electron capture:
[itex]Hg^{196}_{80} + e^- + energy \rightarrow Au^{196}_{79} + \nu_e[/itex]
Are there certain configurations/polarizations I can rule out due to the spin?
Does the negative beta decay energy it lists in the table mean this capture would require the electron have have at least ~ 4.4MeV of energy?
Any help understanding these tables would be great.
JustinLevy said:
[itex]Hg^{196}_{80} + e^- + energy \rightarrow Au^{196}_{79} + \nu_e[/itex] .
Ah, you are looking for the Stone :-p. Ok, trick is first to do alpha from Hg to Pt, then beta from Pt to Au stable. In this way the energy balance is favorable, but as you say you could still have some issue with angular momentum, plus a very very slow rate (so you need the Stone, of course... and it is not easy to find in the market Joachimsthal black, nowadays. Of course you could do a "particular".).
About reading the tables, I have always some doubt about the electron binding energy. I believe that the tables are always for neutral atoms, so it is accounted. But no sure.
What do they mean by spin in those tables?
I'm starting to realize it clearly doesn't mean what I thought (I was taking it to be the total angular momentum of the nucleus. But if that was the case, it wouldn't mean anything to give a sign in front of it ... yet there are some nuclei in the full table it lists as spin=+2 and some as spin=-2).
http://atom.kaeri.re.kr/cgi-bin/nuclide?nuc=Au184 ... shows a state with spin = 2+
http://atom.kaeri.re.kr/cgi-bin/nuclide?nuc=Au196 ... shows a state with spin = 2-
Just understanding what they mean by spin here, and what the sign means, would be quite useful.
The http://www.nndc.bnl.gov/chart/reColor.jsp?newColor=dm" refers to your charts "spin" numbers as "Jπ"
http://www.nndc.bnl.gov/chart/help/glossary.jsp#jpi"
The angular momentum (J) and parity (π) associated with a nuclear level or a particle. For instance, the ground states of nuclei with even number of protons and neutrons have Jπ=0+. The intrinsic Jπ of the proton is equal to 1/2+.
This looks correct to me.
Right. The maximum angular momentum they could take away in the form of spin would be 1/2+1/2=1. But they also carry orbital angular momentum, which brings the total up to 2 in this case.
This is a notation for the parity of the state. The usual notation in nuclear physics is to write the parity to the right, as a superscript.
Ordinarily when we talk about electron capture, we're talking about the capture of an electron in an inner shell of the atom. Such an electron would have an energy in the low keV range, so there's no way you'd get one with 4.4 MeV of energy. The reaction you've written is still possible in theory, but it's not obvious to me that there's any situation where it would actually happen. In an accelerator, I think the cross-section would be way too low to detect, since it's a weak-force process. Conceivably this could happen in a white dwarf or something, assuming you had some heavy nuclei around. I don't think there's any easy way to rule out any possibilities according to spin. The minimum angular momentum for the final state is 3/2, so the incoming electron has to have at least 1 hbar of orbital angular momentum, which is perfectly possible. I don't think the parity of the incoming electron is constrained, since the outgoing neutrino's parity could be + or -.
Related to Au-196 decay: help reading tables
1. What is Au-196 decay?
Au-196 decay is a process in which a radioactive isotope of gold, specifically gold-196, undergoes radioactive decay and transforms into a different element.
2. How does Au-196 decay occur?
Au-196 decay occurs through a process called beta decay, where a neutron in the nucleus of the gold atom is transformed into a proton, releasing an electron and an antineutrino. This results in a new element, platinum-196, being formed.
3. What is the half-life of Au-196?
The half-life of Au-196 is approximately 6.17 days. This means that after 6.17 days, half of the original sample of Au-196 will have decayed into platinum-196.
4. How is Au-196 decay measured?
Au-196 decay is measured using a decay table, which lists the amount of Au-196 remaining at different time intervals. The decay is measured by counting the number of radioactive particles emitted per unit of time.
5. What are the practical applications of studying Au-196 decay?
Studying Au-196 decay can help scientists understand the behavior of radioactive isotopes, which has practical applications in fields such as nuclear energy, medicine, and environmental science. Additionally, the decay of Au-196 can be used for radiometric dating, allowing scientists to determine the age of objects containing gold.
