Autocatalytic reaction and rate of reaction
In summary, the student is trying to model an autocatalytic reaction and is having difficulty understanding the chemistry. He has found an equation that describes the chain termination process, but is not sure how to calculate the mixture temperature.
squaremeplz
124
Hi, I am trying to set up a mathematical model for an autocatalytic (self heating) reaction. However, I can't fully grasp the chemistry.
A + X = B + 2X,
X + Y = B + 2Y,
A + Y = B.
So one example I found is the all known reaction of hydrogen and oxygen, assuming the following conditions:
Let free atoms of hydrogen or oxygen arise as primers in a mixture of O2 and H2 a chain reaction arises:
O_2 and H_2 = OH + O,
O + H_2 = OH + H,
… (Basic Chain)
Next, the hydroxyl radicals OH are formed and these take part in a subsequent reaction
OH + H2 = H20 + H
As a result, the concentration of free hydrogen atoms rises in a geometric progression. Free atoms and radicals are short-lived active intermediate reaction products. They quickly recombine on the walls of the vessel or bulk. The reaction of Chain termination is usually written as:
H + wall = ½ H2
H + O2 + M = HO2 + M
Where M is an arbitrary third particle. As seen from the above reaction, the chain termination in the bulk does not lead to a stable molecule but o the peroxide-type radical HO_2, which still contains superfluous chemical energy and is a long-lved active intermediate. This radical can participate in slow chain propagating reactions:
HO2 + H2 = H2O2 + H
HO2 + H2 = H2O + OH
This type of reaction exhibits a slow increase in the rate of the overall process with time. In order to fully describe the kinetics of the reaction, we must introduce yet another degradation of the perodixed radical on the surface of the walls of the vessel (slow chain termination)
HO_2 + wall -> destruction
And autocatalytic process of chain propagation:
HO2 + H2O = H2O2 + OH
HO2 + H2P2 = H2O + O2 + OH
The last equation explains the phenomenon of autocatalysis in the final reaction product, i.e. Water. On one hand, the rate of the autocatalytic reaction increases markedly with pressure, and this may lead to thermal explosions, as we will investigate in detail.
In order for my model to work, theoretically, the reaction needs to undergo self heating leading towards increased reaction rate, eventually the heat produced will achieve a critical value at which point an explosion occurs.
Can i use the reaction above, and if so, how would I set up the arrhenius source constant,
k = z*e^(-E/RT) where is z is the collision between atoms, and e^(-E/RT) the probability of a collision leading towards a reaction.
Any help is greatly appreciated.
I am not sure if you HAVE to start with chemistry.
I did something similar eons ago - I just assumed A -> B, k given by Arrhenius equation, amount of heat evolved proportional to amount of products, and mixture temperature calculated using simple q=mcΔT. As far as I remember I got a differential equation that yielded integral that I wasn't able to calculate, but it wasn't hard to integrate numerically.
That was after some organic lab - I don't remember what I was doing, but it required ice bath and at some moment mixture got too hot... I had to clean whole fume hood
Hello, it seems like you are trying to understand and model the kinetics of an autocatalytic reaction. An autocatalytic reaction is a type of reaction where one of the products acts as a catalyst for the reaction, leading to a self-sustaining chain reaction. In your example, the peroxide-type radical HO2 acts as the catalyst for the reaction, leading to a slow increase in the rate of the overall process with time. This type of reaction can exhibit self-heating and can potentially lead to thermal explosions if the heat produced exceeds a critical value.
To set up a mathematical model for this type of reaction, you can use the Arrhenius equation that you mentioned. The Arrhenius equation relates the rate constant (k) to the temperature (T) and the activation energy (E) of the reaction. In this case, the activation energy would include the energy required for the collision between atoms (z) and the probability of a collision leading towards a reaction (e^(-E/RT)). You can use experimental data to determine the values of z and E for your specific reaction and then plug them into the Arrhenius equation to calculate the rate constant (k) at different temperatures.
Additionally, it is important to consider the effects of pressure on the reaction, as you mentioned in your post. Changes in pressure can affect the rate of the reaction and can also lead to changes in the critical temperature for thermal explosions. Therefore, it may be necessary to also incorporate pressure into your mathematical model.
I hope this helps in setting up your model and understanding the chemistry of an autocatalytic reaction. It is a complex process, but with careful consideration of the factors involved, you can create a successful mathematical model. Good luck with your research!
Related to Autocatalytic reaction and rate of reaction
1. What is an autocatalytic reaction?
An autocatalytic reaction is a type of chemical reaction in which one of the products of the reaction acts as a catalyst for the reaction itself. This means that the reaction speeds up as more of the product is formed, creating a positive feedback loop. Autocatalytic reactions are often self-sustaining and can lead to explosive or runaway reactions if not properly controlled.
2. How does an autocatalytic reaction affect the rate of reaction?
An autocatalytic reaction can greatly increase the rate of reaction compared to a non-autocatalytic reaction. This is because the catalyst (one of the products of the reaction) speeds up the reaction, leading to more products being formed in a shorter amount of time. As the reaction progresses, more catalyst is produced, further increasing the rate of reaction.
3. What are some examples of autocatalytic reactions?
One common example of an autocatalytic reaction is the Belousov-Zhabotinsky reaction, which involves the oxidation of organic compounds by bromine in the presence of an acid catalyst. Another example is the reaction between hydrogen peroxide and potassium iodide, which also produces an acid catalyst that speeds up the reaction.
4. How can the rate of an autocatalytic reaction be controlled?
The rate of an autocatalytic reaction can be controlled by adjusting the concentration of the reactants, the temperature, or the presence of any inhibitors. In some cases, adding a second catalyst can also help regulate the rate of the reaction. It is important to carefully monitor and control autocatalytic reactions to prevent them from becoming dangerous or uncontrollable.
5. What are the potential uses of autocatalytic reactions?
Autocatalytic reactions have potential applications in various industries, such as in the production of pharmaceuticals and chemicals. They can also be used in self-healing materials, where the reaction can repair any damage or defects in the material. Additionally, autocatalytic reactions are being studied for their potential role in the origin of life on Earth, as they are thought to have played a role in the early chemical evolution of living organisms.
