Automatic parking slots detection using Python
In summary: I have a Deep Machine Learning course and would like to do my course project about "Available Parking Slots Detection using Deep Machine Learning Based on Image Processing".So it sounds like you have some flexibility in your project definition then? In that case, it would probably help the success of your project (and your grade) if you could pick a practical application to apply your program to.I'd suggest doing some more research on practical parking space applications, and then chosing one of those or focusing on the airport parking lot application with fixed security cameras. Airport parking lots will typically have lots of cameras for security monitoring, so piggybacking on that infrastructure to add a big customer convenience application like available parking spot identification
falyusuf
35
TL;DR Summary: How to automatically detect the parking slots using Python?
My plan is to split the project into two parts: selector part and detector part.
For the selector part; how to automatically select the parking slots in the parking area? using what algorithms?
Technology news on Phys.org
Since this is for a schoolwork project, please tell us what you have found so far. Also, how are you going to be given the input data? Will it be some video file that is recorded while driving around a parking lot or something? What are the constraints on that video input? Time of day/night, lighting, shadows, parking stall markings, backgrounds, etc.?
What is your experience so far with Python?
Several related works have manually selected parking slots using different methods, such as selecting the region of interest (ROI) through mouse clicks or determining the coordinates of each parking slot through trials and errors (which I used in my previous course project). However, these methods are not practical for large-scale parking areas and are challenging to use when selecting parallel parking spaces. Therefore, I am searching for automatic parking slot detection and updating my previous project.
I have prior experience with Python in a project that involved detecting parking slot availability through image processing. In that project, I took a picture of the parking area and manually selected the slots, as previously mentioned. I then segmented the image into five images, each representing a parking slot. The next step involved converting each image from RGB to grayscale, using the Canny function to obtain edges, counting the white pixels in each edge image, and determining if the number of white pixels was large enough to classify the parking slot as occupied (if there was a car) or free.
Challenges: Manually selection of parking slots. The challenge is that rain spots on the parking slots themselves may be detected as white pixels in the edge image, leading to incorrect detection.
My new idea is: Record a video from a high vantage point of the parking area using a laptop webcam. Use algorithms to automatically detect the parking slots and load a large dataset of images of free and occupied parking slots in Python to train a predictive model. The model will determine whether the parking slot is free or busy, and the border color of the slot will change to green or red, respectively, to indicate its status.
Likes berkeman
I understand that this is a school project, but is there a projected application in mind? For example, for fixed cameras in an airport parking lot to be able to identify available empty slots to direct airport customers to? Or fixed cameras in a parking structure to direct customers to?
Any example pictures or videos that you can post will help this discussion.
Not yet.
I searched for projects in this topic but still did not get any.
falyusuf said:
Not yet.
I'd suggest doing some more research on practical parking space applications, and then chosing one of those or focusing on the airport parking lot application with fixed security cameras. Airport parking lots will typically have lots of cameras for security monitoring, so piggybacking on that infrastructure to add a big customer convenience application like available parking spot identification would be a good thing.
Maybe check out typical airport parking lot video monitoring setups (if you can get security clearance for that) to see what the coverage and video artifacts look like.
Yes, we can choose any topics related to Deep Machine Learning. I can redo my previous project in a different way; by training a model using deep ML. However, I want to improve it even more by selecting the slots automatically and that's what I am looking for.
Here's some of the results from my previous project.
FAQ: Automatic parking slots detection using Python
How does automatic parking slot detection using Python work?
Automatic parking slot detection using Python works by using image processing techniques to analyze images or video footage of parking lots. The program detects empty parking spots by comparing the images to a reference image of the parking lot without any cars. It then highlights or marks the empty parking slots to assist drivers in finding available spots.
What tools or libraries are commonly used for automatic parking slot detection using Python?
Commonly used tools and libraries for automatic parking slot detection using Python include OpenCV for image processing, NumPy for numerical computing, and Matplotlib for visualization. These libraries provide the necessary functions and algorithms for detecting and marking parking slots in images or video streams.
Can automatic parking slot detection using Python be integrated with existing parking management systems?
Yes, automatic parking slot detection using Python can be integrated with existing parking management systems. The detected information about available parking slots can be sent to the parking management system in real-time, allowing the system to provide accurate and up-to-date information to drivers about available parking spaces.
Is automatic parking slot detection using Python accurate and reliable?
The accuracy and reliability of automatic parking slot detection using Python depend on the quality of the images or video footage, the effectiveness of the image processing algorithms, and the calibration of the system. With proper tuning and optimization, automatic parking slot detection using Python can achieve high accuracy and reliability in detecting empty parking slots.
Are there any limitations or challenges when implementing automatic parking slot detection using Python?
Some limitations and challenges when implementing automatic parking slot detection using Python include variations in lighting conditions, occlusions from other objects or vehicles, and the need for regular calibration and maintenance of the system. Additionally, the performance of the system may be affected by factors such as camera quality and positioning.
