sk1329
- 8
Automobiles -- why not to remain in 1st gear?
why not to remain in 1st gear ??
First of all, please speak in correct English and complete sentences. It is difficult to understand when you write so poorly.sk1329 said:forget about the 2nd reason you gave because it is inevitable...but can't we increase the range of rpm
Staying in 1st gear for extended periods of time can cause damage to your engine and transmission. It puts unnecessary strain on these components and can lead to costly repairs.
No, staying in 1st gear does not save fuel. In fact, it can actually decrease your fuel efficiency. This is because your engine is working harder to maintain the high RPMs in 1st gear, using more fuel in the process.
Yes, driving in 1st gear can put extra strain on your brakes. This is because you may need to constantly brake to maintain a safe speed, causing your brake pads to wear out faster. It is also not recommended to use your brakes to control your speed, as this can cause them to overheat and potentially fail.
Yes, 1st gear can be useful for steep inclines or declines to maintain a slow and steady speed. However, it is important to shift into the appropriate gear once you reach a flatter terrain to avoid engine strain.
Yes, driving in 1st gear for extended periods of time can be uncomfortable and noisy. It can also cause your vehicle to jerk and lurch, making for a less smooth and enjoyable driving experience.
