MHB Automorphisms of an extension field
  • Thread starter Thread starter Bingk1
    Extension Field
Bingk1
Hello, I found this question, and I was able to do the easier parts, but I'm really not comfortable with automorphisms in fields.
Let f(x)=x^2 + 1 = x^2 - 2 \in Z_3[x].
Let u= \sqrt{2} be a root of f in some extension field of Z_3.
Let F=Z_3(\sqrt{2}).
d)List the automorphisms of F which leave Z_3 fixed.
What I did is as follows:
a=1+\sqrt{2} generates the nonzero elements of F, which is a finite field.
The automorphisms of the multiplicative group of F is isomorphic to the group U(9)=\{1,2,4,5,7,8\}.
Since [F:Z_3]=2, we know that there will be 2 automorphisms which fix Z_3, and that these 2 automorphisms form a group, so the non-identity automorphism should have order 2.
This gives us the two automorphisms: \sigma_1: a \mapsto a and \sigma_2: a \mapsto a^8.
Is what I've done okay? Any comments/suggestions?
Also, I just wanted to make sure that I've remembered correctly. Technically, Z_3(\sqrt{2}) is supposed to consist of elements of the form \frac{f(u)}{g(u)} (taken modulo 3) where f,g \in Z_3[x] and g \neq 0, but because u is algebraic over Z_3, we can say that Z_3(\sqrt{2}) consists of elements of the form f(u). Is this right?
there is really no need to mention Aut(U(9)).
as it turns out, you have the wrong group there, anyway: there are but 8 non-zero elements of Z3(u), so the field automorphism group must be (isomorphic to) a subgroup of U(8) = {1,3,5,7}.
let's look at the powers of 1+u:
(1+u)2 = 1 + 2u + u2 = 2u
(1+u)3 = (1+u)(2u) = 2u + 2u2 = 2u + 2(2) = 1 + 2u
(1+u)4 = (2u)2 = u2 = 2 <--this shows that 1+u has order 8.
(1+u)5 = (2)(1+u) = 2 + 2u
(1+u)6 = (1+u)(2+2u) = 2 + 2(2u) + 2u2 = (2+1) + u = u
(1+u)7 = (u)(1+u) = u + u2 = 2 + u
(1+u)8 = (2+u)(1+u) = 2 + (1+2)u + u2 = 2 + u2 = 2 + 2 = 1.
now a field automorphism σ must also be an automorphism of the multiplicative group, hence we have:
σ(1+u) = 1+u, (1+u)3, (1+u)5 or (1+u)7.
but a field automorphism must also be an additive homomorphism, so:
0 = σ(0) = σ(u2 + 1) = σ(u2) + σ(1) = σ(u)2 + 1, so σ(u) must also be a root of x2 + 1 in Z3[x]. clearly this "other root" is 2u (= -u):
(x - u)(x - 2u) = x2 -(u + 2u)x + 2u2 = x2 + 2u2 = x2 + (2)(2) = x​2 + 1.
so σ(1+u) = σ(1) + σ(u) = 1 + σ(u) = 1 + 2u = (1+u)3.
it would be nice to express σ solely in terms of what it does to u:
σ(u) = 2u = (u2)(u) = u3.
of course, this makes sense, in any ring of characteristic p, a→ap, is a ring homomorphism.
we have not "yet" shown that σ so defined is actually an additive isomorphism, that is:
σ(a+bu) = 0 iff a = b = 0 (where a,b are in Z3).
however, σ(a+bu) = σ(a) + σ(bu) = σ(a) + σ(b)σ(u)
= a + bσ(u) = a + bu3 = a + 2bu,
so if σ(a+bu) = 0, a = 0, 2b = 0, whence b = (2)(2b) = (2)(0) = 0.
(note that we used the fact that in Z3, a3 = a for all a:
03 = 0
13 = 1
23 = 2(22) = 2((2)(2)) = 2(1) = 2).
it should be clear that {id,σ} forms a group of order 2:
σ2(a+bu) = σ(σ(a+bu)) = σ(a+2bu) = σ(a) + 2bσ(u) = a + 2b(2u) = a + bu,
so σ2 = id.
it might be instructive for you to examine WHY:
σ:1+u → (1+u)5
σ:1+u → (1+u)7
do not lead to additive homomorphisms.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
