-aux.13.Normal Distribution area
In summary, the graph shows a normal curve for the random variable X, with mean 10 and standard deviation 1.56. It is known that P(X>12) = 0.1 and P(X<8) = 0.1.
karush
MHB
3,269
still having trouble figuring this out!
The graph shows a normal curve for the random variable \(\displaystyle X\), with mean \(\displaystyle \mu\) and standard deviation \(\displaystyle \sigma\)
It is known that \(\displaystyle P \left(X \geq12 \right) = 0.1\).
(a) The shaded region \(\displaystyle A\) is the region under the curve where \(\displaystyle x \geq 12\). Write down the area of the shaded region \(\displaystyle A\).
It is also known that \(\displaystyle P(X \leq 8) = 0.1\).
(b) Find the value of \(\displaystyle \mu\), explaining your method in full.
in that \(\displaystyle \mu\) is in between 8 and 12 which would be \(\displaystyle \mu=10\)(c) Show that \(\displaystyle \sigma = 1.56\) to an accuracy of three significant figures.
(d) Find \(\displaystyle P(X \leq 11)\).
Mathematics news on Phys.org
Seriously? You were just told that this area is 0.1!
in that \(\displaystyle \mu\) is in between 8 and 12 which would be \(\displaystyle \mu=10\).
Okay, Since the graph of the normal distribution is symmetric about mu, and you are told that the probabilities that x is less than 8 and larger than 12 are equal, mu is exactly half way between them
If a normal distribution has mean 10 and standard deviation \(\displaystyle \sigma\), then \(\displaystyle \frac{x- \mu}{\sigma}\) has standard normal distribution. Look up the "z" that has probability .1 in a table of the standard distribution (a good one online is at Standard Normal Distribution Table) then solve \(\displaystyle \frac{12- 0}{\sigma}= z\)
Knowing both \(\displaystyle \sigma\) and \(\displaystyle \mu= 10\) you can find the "standard" variable \(\displaystyle z= \frac{11- 10}{\sigma}\) using the table of the normal distribution.
(a) You are given that:
What relationship is there between this and the shaded region?
(b) Using the given:
We may state:
\(\displaystyle 8<\mu<12\)
and by symmetry:
\(\displaystyle \mu-8=12-\mu\)
Note: we are simply stating mathematically that the mean is midway between $X=8$ and $X=12$.
(c) We know that:
\(\displaystyle z=\frac{\mu-x}{\sigma}\)
or:
\(\displaystyle \sigma=\frac{\mu-x}{z}\)
Once we know $\mu$, and we use $x=12$, what $z$-value should we use? What area is to the left of $x$ but to the right of $\mu$?
(d) Once we have $\sigma$, we may standardize $X=11$ (convert it to a $z$-score) and then use our table to determine \(\displaystyle P(X \leq 11)\).
So, what do you find? :D
I see, before I post, that another has posted, but I figure we are saying the same thing in slightly different ways, and I am not giving anything further away. :D
well from the table I found $0.5-0.1=0.4$ so $0.4$ on table is $\approx 0.3997$ or a $z$ value of $1.28$
so $\frac{|10-12|}{1.28}=1.56 = \sigma$
I assume the numerator has to be a abs value
MarkFL said:
(d) Once we have $\sigma$, we may standardize $X=11$ (convert it to a $z$-score) and then use our table to determine $P(X \leq 11)$.
so $\frac{10-11}{1.56} = z =.64$ from table is $.2389 = P(X \leq 11)$
however don't we include what is left of $\mu$ which would add $.5$ which would give us $\approx .7389$
Correct, and correct. :D
FAQ: -aux.13.Normal Distribution area
1. What is the "-aux.13.Normal Distribution area"?
The "-aux.13.Normal Distribution area" refers to a specific area under a normal distribution curve. This area is calculated using a standard normal table or a calculator and represents the probability of a random variable falling within a certain range.
2. How is the Normal Distribution area calculated?
The Normal Distribution area is calculated by finding the probability of a random variable falling within a specific range under a normal distribution curve. This can be done by using a standard normal table or a calculator, which uses the mean and standard deviation of the distribution to find the area.
3. What does the Normal Distribution area tell us?
The Normal Distribution area tells us the probability of a random variable falling within a certain range under a normal distribution curve. This can help us understand the likelihood of certain events occurring and make predictions based on the distribution of a given data set.
4. How is the Normal Distribution area used in statistics?
The Normal Distribution area is used in statistics to calculate probabilities and make predictions based on data that follows a normal distribution. It is also used to compare different data sets and determine if they are significantly different from each other.
5. Can the Normal Distribution area be negative?
No, the Normal Distribution area cannot be negative as it represents the probability of a random variable falling within a certain range. Since probabilities cannot be negative, the Normal Distribution area will always be a positive value.
