MHB -aux04 Species of insect is normally distributed
The lifespan of a specific insect species follows a normal distribution with a mean of 57 hours and a standard deviation of 4.4 hours. Standardization of the lifespan values yielded z-scores of -0.45 for 55 hours and 0.68 for 60 hours. The probability of an insect living more than 55 hours is approximately 67%, while the probability of living between 55 and 60 hours is around 43%. Further calculations using rational numbers provided similar results for these probabilities. A follow-up question regarding the lifespan of 90% of the insects will be addressed in future discussions.
karush
MHB
just seeing how I did on this one:confused:
The lifespan of a particular species of insect is normally distributed with a mean of $57$ hours and a standard deviation of $4.4$ hours.
this is the normal distribution with $\mu = 57$ and $\sigma = 4.4$
tried to standardize this by $\frac{55-75}{4.4}=-0.45$ and $\frac{60-57}{4.4}=0.68$
with $\mu = 0$ and $\sigma = 1$ and $P(-0.45 < x < 0.68)$
which hopefully looks like the given graph on the right belowhttps://www.physicsforums.com/attachments/1027View attachment 1028
(a) What are the values of $a$ and $b$
from the standard $\frac{x-\mu}{\sigma} a=-0.45$ and $b=0.68$
(b) Find the probability that the lifespan of an insect of this species is more than $55$ hours
$P(55 < X)$ from $z$ score $0.45$ then $0.1736 + .5 = .6736$ or $\approx 67\%$
(b) Find the probability that the lifespan of an insect of this species is between $55$ and $60$ hours
$0.2517+0.1736=0.4253$ or $\approx 43\%$
Mathematics news on Phys.org
Re: species of insect is normally distributed
Using rational numbers instead of decimal approximations:
a) $$a=-\frac{5}{11},\,b=\frac{15}{22}$$
Using numeric integration for comparison:
b) $$P(55<X)\approx0.675282$$
c) $$P(55<X<60)\approx0.427605$$
I would say you did them correctly.
well that is encouraging. there still is one more question on this but I will post it tomorrow. :)
90% of the insects die after t hours.
(i) Represent this information on a standard normal curve diagram indicating clearly the area representing $90\%$.
(ii) Find the value of $t$.does this mean $P(X < t)$, also should $60 < t$ I don't see where this $90\%$ is supposed to be since P(55 < X < 60) was [FONT=MathJax_Main]0.427605
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
