Available Wind Energy Calculation
In summary, "Available Wind Energy Calculation" involves assessing the potential energy that can be harnessed from wind in a specific area. This calculation typically uses parameters such as wind speed, air density, and the rotor area of wind turbines to estimate the energy output. Factors like local topography and seasonal variations are also considered to enhance accuracy. Ultimately, the goal is to determine the feasibility and efficiency of wind energy projects by quantifying the amount of power that can be generated from wind resources.
keith0101
TL;DR Summary
Why we take area of disc, instead of area of ambient air in the assumption of mass flow rate when calculating the available wind energy? Isn't it a contradiction to conservation of mass?
For the avaliable power to be harvested in free-streaming wind:
P=1/2QU^2_infinite (Q: mass flow rate, U_infinite: velocity of free-streaming wind)
And
Q is defined as: p x U_infinite x A_d. (p: density of air, A_d: Area of disc)
I cannot understand the reason of taking the area of disc, A_d, instead of area of ambient air, A_infinite, in the assumption of Q, since under the conservation of mass:
p*U_infinite*A_infinite = p*U_d*A_d = p*U_w*A_w
Welcome to PF, Keith.
keith0101 said:
here in the 2nd slide
What 2nd slide? What presentation? Please always provide links to your source material when posting on PF (and to avoid copyright violations). Thanks.
Hi,
For 2nd slide I mean the equation of avalible power in wind, which is:
And
Please post links to your sources for that material, Keith, or your post will be deleted for a copyright violation.
UPDATE - it appears that the OP's solution was to delete the attachments...
Likes russ_watters
You use disk area because the only air you can harvest is that which flows through the disk. Yes, there's much more total air power, but you don't care about the air flowing around the disk, you only care about the air that you could theoretically capture.
Likes berkeman
FAQ: Available Wind Energy Calculation
What factors are considered in calculating available wind energy?
Calculating available wind energy involves considering several factors, including wind speed, air density, the swept area of the wind turbine blades, and the efficiency of the wind turbine. Wind speed is the most critical factor, as wind energy increases with the cube of the wind speed. Air density can vary with altitude and temperature, affecting the energy potential. The swept area is the circular area covered by the rotating blades, and larger areas capture more wind. Finally, turbine efficiency determines how much of the wind's kinetic energy can be converted into usable electrical energy.
How is wind speed measured for wind energy calculations?
Wind speed is typically measured using anemometers, which are devices that can be mounted on a mast or tower at the height of the wind turbine hub. These measurements are often taken over a period of time to determine the average wind speed at a specific location. Wind speed data can also be obtained from meteorological stations, satellite observations, and wind maps. Accurate wind speed measurements are crucial for estimating the potential energy output of a wind turbine.
What is the formula for calculating the power available in the wind?
The power available in the wind can be calculated using the formula: P = 0.5 * ρ * A * V^3, where P is the power available in watts, ρ (rho) is the air density in kilograms per cubic meter, A is the swept area of the turbine blades in square meters, and V is the wind speed in meters per second. This formula shows that power increases with the cube of the wind speed, making wind speed a critical factor in wind energy calculations.
How do you account for turbine efficiency in wind energy calculations?
Turbine efficiency is accounted for by applying a coefficient known as the power coefficient (Cp), which represents the fraction of the wind's kinetic energy that can be converted into electrical energy by the turbine. The maximum theoretical value of Cp is 0.59, known as the Betz limit, but practical turbines have a Cp ranging from 0.3 to 0.5. The actual power output of the turbine is calculated by multiplying the available wind power by the power coefficient: P_actual = P_available * Cp.
What role does air density play in wind energy calculations?
Air density affects the amount of energy available in the wind. It is influenced by altitude, temperature, and atmospheric pressure. Higher air density means more mass flow through the turbine blades, resulting in more energy capture. The standard air density at sea level and at 15°C (59°F) is approximately 1.225 kg/m³. Adjustments must be made for different conditions, as lower air density at higher altitudes or higher temperatures will reduce the available wind energy
41K
12K
