Average acceleration from acceleration vs time graph
In summary, to find average acceleration from an acceleration vs. time graph, you need to find the overall change in velocity by calculating the area under the curve. The average acceleration can then be represented as a rectangle of fixed height on the graph. It's important to note that without knowing the initial velocity, you can only find the change in velocity, not the exact velocity itself.
swirly90
I have a few question regarding Acceleration, I am not sure exactly how to get average acceleration from a acceleration vs. time graph. Do you make a slope? I drew a sample graph, say get the average acceleration from 11s - 25s? Would you try to draw a slope between the two time intervals?
How do you find velocity on a graph like this? Is the area from the line to the zero line?
Thanks for your help.
(Instantaneous) acceleration is the quotient of some tiny change in velocity divided by the tiny time interval during which the change occurs. Average acceleration is the quotient of some overall change in velocity divided by the overall time interval during which the change occurs. So, if you have this plot of (instantaneous) acceleration in time, the first thing to do is to figure out the overall change in velocity. Then, divid this by the time interval. The change in velocity is the "area under the curve". That is, the change in velocity is the integral of the acceleration over time. If the curve is negative, subtract the area. If the curve is positive, add the area.
The average acceleration can be represented as a rectangle of fixed height on this graph. The base of the rectangle is from zero to 35 s. The height of the rectangle should be such that the area of the rectangle (base*height) is the same as the area under the graph that is given. So the first step is to find the area under the graph above. This would be the sum of two positive and one negative areas.
Without knowing the initial velocity, you can't technically know the velocity of the object. What you CAN know is the overall change in velocity, which as kuruman explained is adding / subtracting the area under the curve depending on whether it's positive/negative.
:smile:
Thanks, so "under the line" its not velocity but the change in velocity?
In some ways, yes - but you don't know where you started initially with the velocity.
In your example graph (assuming the line is zero and each little box is 1 m/s/s high, that scale is a bit off), you'd get:
60 - 48 + 16 = +28 m/s
So you'd be 28 m/s faster than what you started at.
But considering that you could have started at 0 m/s, or 5 m/s, I can't know for sure exactly how fast you're going from that graph, only the overall change.
Related to Average acceleration from acceleration vs time graph
What is the definition of average acceleration?
Average acceleration is the rate at which an object's velocity changes over a given period of time. It is calculated by dividing the change in velocity by the change in time.
How is average acceleration calculated from an acceleration vs time graph?
To calculate average acceleration from an acceleration vs time graph, you can use the slope of the line. The slope of the line represents the change in velocity over the change in time, which is the definition of average acceleration.
What does the slope of an acceleration vs time graph represent?
The slope of an acceleration vs time graph represents the rate of change of acceleration. It tells us how quickly the acceleration is changing over time.
How can you tell if an object is accelerating or decelerating from an acceleration vs time graph?
If the slope of the acceleration vs time graph is positive, the object is accelerating. If the slope is negative, the object is decelerating. If the slope is zero, the object is moving at a constant velocity.
How does the shape of an acceleration vs time graph relate to an object's motion?
The shape of an acceleration vs time graph can give information about the type of motion an object is experiencing. For example, a straight line with a positive slope represents constant acceleration, while a curved line represents changing acceleration.
