Average chord length of a circle
In summary, the conversation discusses the different methods for finding the average chord length of a circle and how they can lead to different answers. The main point is that the definition of average can greatly affect the result, and there is no one correct way to define it. The conversation also discusses the correct way to obtain a random chord and shows that the average length is equal to 4R/π.
serverxeon
101
I would like to find the average chord length of a circle.
And I have 2 methods, which gave different answers...
[The chord is defined as the line joining 2 points on the circumference of the circle.]
The general formula for a chord length is ##d=2R\sin(\delta/2)=2\sqrt{R^2-u^2}##
Method 1: Integrate over angles
Avg length = $$\frac{\int_0^{2\pi} 2R\sin(\delta/2)\,d\delta}{2\pi}$$
$$=\frac{4R}{\pi}$$
Method 2: Integrate over diameter (-R to R)
Avg length = $$\frac{\int_{-R}^{R} 2\sqrt{R^2-u^2}\,du}{2R}$$
After simplification
$$\int_{-R}^{R} \sqrt{1-\left(\frac{u}{R}\right)^2}\,du$$
Then, using the fact
$$\int_{-Z}^{Z} \sqrt{1-\left(\frac{u}{Z}\right)^2}\,du = \frac{Z\pi}{2}$$
I get
$$=\frac{R\pi}{2}$$
So the answers from my 2 methods don't add up. Any things i might have overlooked?
Mathematics news on Phys.org
You found two different definitions for the average. The question "what do you average over?" is not just interesting for the calculation, it leads to different mathematical questions - with different answers.
I am not too sure. Are they not the same?
However, even if I ignore the different definition of average and solely look at the 'sum of all chords',
I get (for angles) ##8R## and (for diamater) ##R^2\pi##
Am I not simply summing up all possible chord lengths from 0, to 2R, then back to 0 again?
There is an infinite set of chords, there is no unique way to “sum” over them.
An analogy: Let ##a=b^2##. Clearly a=b has the solutions a=b=0 and a=b=1. But the integrals between these limits are different: $$\int_0^1 a da \neq \int_0^1 b^2 db$$
The key point here is ##da \neq db## - it matters how you integrate.
Your example is not exactly correct.
If you substituted $$a=b^2$$
then
$$\int_0^1 a\, da = \int_0^1 {b^2\cdot2b}\,db$$
which is then the same...
Anyway,
Did you mean to say there is ONE set of infinite chords, or there are infinite sets of finite chords?
Because you seem to suggest the former, and that would mean there should only be one unique answer?
There is one set of infinite chords. However, there are many possible ways to define the probability distribution. Your analysis uses two different ones, so it is not surprising to get two different answers for the mean.
Yes, but you had to introduce the factor 2 b. That's the point. A change in coordinates can change the integral if you do not add factors like these.
The one true way to obtain a random chord, is to uniformly pick two points P,Q on the circle. These choices amounts to a uniform choice of angles [itex]\theta,\phi \in [0,2\pi)[/itex]. The angle POQ, where O is the center, is equal to [itex]\sqrt{2R^2-2R^2\cos(\theta-\phi)} = \sqrt{2}R\sqrt{1-\cos(\theta - \phi)}[/itex] by the cosine formula (note that the sign of [itex]\theta - \phi[/itex] does not matter here). The average length thus becomes
[tex] \frac{\int^{2\pi}_0 \int^{2\pi}_0 \sqrt{2}R\sqrt{1-\cos(\theta - \phi)}d\theta d \phi}{\int^{2\pi}_0 \int^{2\pi}_0 d\theta d\phi} = \frac{\int^{2\pi}_0 \int^{2\pi}_0 \sqrt{2}R\sqrt{1-\cos(\theta - \phi)}d\theta d \phi}{(2\pi)^2}[/tex]
Evaluating the inner integral first, it is clear that as [itex]\phi[/itex] varies as a constant, the integral remains unaffected. So
[tex] \int^{2\pi}_0\left( \int^{2\pi}_0 \sqrt{2}R\sqrt{1-\cos(\theta - \phi)}d\theta \right) d \phi = \int^{2\pi}_0\left( \int^{2\pi}_0 \sqrt{2}R\sqrt{1-\cos(\theta)}d\theta \right) d \phi [/tex]
[tex]= 2\pi \sqrt{2}R \int^{2\pi}_0 \sqrt{1-\cos(\theta)}d\theta = 2\pi \sqrt{2}R \left( \int^{\pi}_0 \sqrt{1-\cos(\theta)}d\theta + \int^{\pi}_0 \sqrt{1+\cos(\theta)}d\theta \right)[/tex]
On the last equality we split the integral in two, and used the fact that [itex]\cos(\theta + \pi) = -\cos(\theta)[/itex]. Next observe that [itex]1-\cos(\theta) = 2\sin^2(\frac{\theta}{2})[/itex] and [itex]1 + \cos(\theta) = 2\sin^2(\frac{\theta}{2})[/itex], so that [itex]\sqrt{1-\cos(\theta)} = \sqrt{2}\sin(\frac{\theta}{2})[/itex] and [itex]\sqrt{1+\cos(\theta)} = \sqrt{2}\cos(\frac{\theta}{2})[/itex] (note that both expressions to the right are positive since we now are integrating over [itex]\theta \in [0,\pi][/itex]!).
Our integral becomes
[tex]2\pi \sqrt{2}R \int^{\pi}_0 \sqrt{2}\left( \sin(\frac{\theta}{2}) + \cos(\frac{\theta}{2}) \right) d\theta = 4\pi R \int^{\pi}_0 \left( \sin(\frac{\theta}{2}) + \cos(\frac{\theta}{2}) \right)d\theta [/tex]
This is easily evaluated, yielding [itex]4\pi R[-2\cos(\frac{\theta}{2})+2\sin(\frac{\theta}{2})]^{\pi}_0 = 16 \pi R[/itex]. By our first formula, we obtain the average length
[tex]\frac{16 \pi R}{(2\pi)^2} = \frac{4R}{\pi}[/tex] which indeed was your first answer.
FAQ: Average chord length of a circle
What is the average chord length of a circle?
The average chord length of a circle is the average distance from the center of the circle to any point on the circumference. It is also known as the radius of the circle.
How is the average chord length of a circle calculated?
The average chord length of a circle can be calculated by dividing the diameter of the circle by two. It can also be calculated using the formula: (2 x radius) / π.
What is the significance of the average chord length of a circle?
The average chord length of a circle is important in many applications, such as geometry, engineering, and physics. It is used to calculate the area, circumference, and other properties of circles.
Can the average chord length of a circle be greater than the diameter?
No, the average chord length of a circle can never be greater than the diameter. The diameter is the longest chord in a circle and the average chord length is always less than or equal to the diameter.
How does the average chord length of a circle relate to other properties of a circle?
The average chord length of a circle is directly related to the radius and diameter of the circle. It is also used to calculate the central angle and arc length of a circle.
