Average distance between water molecules
The average distance between water molecules at room temperature and pressure can be estimated using the density of water, which is 1 g/cm³, and its molecular weight of 18 g/mol. This information allows for the calculation of the number of moles in a given volume, leading to an understanding of molecular spacing. However, direct answers to homework questions are discouraged to promote independent learning. Instead, participants are encouraged to provide hints and guidance. Understanding these concepts is essential for grasping molecular interactions in water.
hgbreton
Does anyone know what the average distance between water molecules at rtp is, or how I could work this out?
Thanks
hgbreton
Taking into account the density of water = 1 Kg/L = 1 g/cm3 and the molecular weight to be 18 g/mol then the number of moles found in unit volume is:
<< complete solution deleted by berkeman >>
thanks!
Welcome to the PF, huda123.
Please take care not to give out answers to homework/coursework questions. It is against the PF Homework Help rules. Please see the "Rules" link at the top of the page.
Please instead provide hints, or clarifying remarks, and be tutorial in your help here. Our goal is to help the original poster (OP) to figure out the problem on their own. After all, that is how they will learn the material the best.
