Average Force Question Given Velocities [High School]
In summary, Nikhil is running away from Old Man Miller when Old Man Miller grabs Nikhil's sandwich out of the air and hits Nikhil in the head with it. The average force the sandwich applies to Nikhil's head is 79N.
Liam C
57
Nikhil is probably eating his daily snack at this time. Old Man Miller comes back from the store and takes the 0.150kg sandwich from Nikhil as he begins to run away. Nikhil is running at 7.5m/s away from me when I hit him in the head with the sandwich that was moving at 17.5m/s when it makes contact with the back of his head. Determine the average force the sandwich applies to Nikhil's head if it is in contact with his head for a period of time which allows the sandwich to move 15cm forward before it falls to the ground.
Where t is time:
t = Δd / (v1 + v2 / 2)
Where Vav is the average velocity:
Vav = Δd / Δt
Where Fav is the average force:
Fav = m × Vav / t
m = 0.150kg
Δd = 15 cm = 0.15m
v1 = 17.5m/s
v2 = 0m/s
t = ?
Fav = ?
t = 0.15 / (17.5 / 2)
t = 0.017s
Vav = 0.15 / 0.017
Vav = 8.82m/s
Fav = (0.150)(8.82) / 0.017
Fav = 79N
∴ The average force applied to Nikhil's head by the sandwich is 79N
I was never taught average force in class so if my understanding is incorrect that is why. That is also why I am not confident in my answer and need help. Is my method correct, and if not where did I go wrong?
There is debate about how to calculate average force. For the purpose of a high school problem, yours is about as good as another, I guess. One thing though: it looks like you have the sandwich going from 17.5 m/s down to zero m/s and take the 'average speed' of that. If the person continues to move forward at the same speed, then the sandwich will "fall off" the person when the sandwich starts to travel slightly slower than the person.
Likes Liam C
Oh! v2 is likely 7.5m/s then. Aha!
Mmmm.. but perhaps in the same way that there is debate about evolution, climate change, vaccinations, ...
@LiamC, average force is defined as change in momentum divided by elapsed time. Unfortunately this question gives no way to find the elapsed time unless you assume the force is constant. If is constant then you can also calculate that force as work/distance, but also if it is constant there is no need to ask for the average.
So the question is fundamentally flawed, but perennially popular.
Likes scottdave
Wow that's very interesting, I'll have to bring that up with my teacher. I believe I'm learning "work" next week so I'm excited to find out what that means exactly.
Related to Average Force Question Given Velocities [High School]
1. What is average force?
Average force is the total force applied to an object over a period of time, divided by the duration of that time. It is a measure of the overall impact or push/pull on an object.
2. How is average force calculated?
Average force can be calculated by dividing the change in an object's momentum by the time interval over which the change occurred. It can also be calculated by multiplying an object's mass by its acceleration.
3. How is average force different from instantaneous force?
Average force is a measure of the overall force applied over a period of time, whereas instantaneous force is the force applied at a specific moment in time. Average force takes into account the duration of the force, while instantaneous force only considers the force at a single point in time.
4. How are velocities related to average force?
Velocities are related to average force through the equation F=ma, where F is the force, m is the mass of the object, and a is the acceleration. This means that the greater the velocities of an object, the greater the force required to change its motion.
5. How is average force used in high school physics?
Average force is used in high school physics to understand the relationship between force, mass, and acceleration. It is also used in equations such as Newton's second law of motion (F=ma) and in calculating work and energy. It is an important concept for understanding the motion of objects and the laws of physics.
9K
