Average height of molecules in a box as a function of temperature
In summary, the average height, z, of monatomic gas molecules in a circular cylinder on Earth is given by the Boltzmann distribution and is dependent on temperature. As temperature approaches 0, z approaches 0, and as temperature approaches infinity, z approaches H/2. To determine the limits, l'Hopital's rule can be used twice or the exponentials can be expanded to second order in BH = mgH/(kT).
Kilian Stenning
A circular cylinder of height H is filled with monatomic gas molecules at temperature T. The cylinder stands on the surface of the Earth so that the gas molecules are subject to the gravitational field g.
(a) Find the average height, z , of the molecules in the cylinder as a function of temperature. (Hint: The probability of finding a molecule at height z is governed by the Boltzmann distribution). Show that for
T → 0, z = 0 , and for T → ∞ , z = H/2 .
f(z) = Cexp(-mgh/kt)
<z> =∫ z fz dz/∫ fz dz
let B=mg/kT
Ive got an answer for <z> to be (1/B)*(1-(e^(-BH))*(BH+1))/(1-e^(-BH))
To get the limits I've tried to use l'hopitals rule w.r.t T but I can't seem to get the right answer
Hello Kilian, :welcome:
The brackets tend to make it hard to read. $$
(1/B)\ * \ (1\ \ -\ \ (\exp(-BH))*(BH+1)\ \ \ )\ \quad /\quad (1-\exp (-BH))
$$Do I see $$ <Z> \ = {kT\over mg} \ \
{ 1 - \left ({mgh\over kT}+1\right ) e^{-{mgh\over kT}} \over
1 - e^{-{mgh\over kT} }} \quad ?$$
In which case I see the ##T\rightarrow 0## limit, but not the other one !
For the T → ∞ case, you will need to use l'Hopital's rule twice. Or you can expand the exponentials to second order in BH = mgH/(kT).
Likes BvU
thanks got it now!
Related to Average height of molecules in a box as a function of temperature
1. What is the relationship between temperature and the average height of molecules in a box?
The average height of molecules in a box is directly proportional to the temperature. As the temperature increases, the average height of molecules also increases.
2. How does the size of the box affect the average height of molecules at different temperatures?
The size of the box does not affect the average height of molecules at different temperatures. The average height of molecules is solely determined by the temperature.
3. Is there a limit to how high the molecules can be at a certain temperature?
Yes, there is a limit to how high the molecules can be at a certain temperature. This limit is known as the thermal velocity of the molecules and is determined by their mass and temperature.
4. How does the average height of molecules affect the pressure of the gas in the box?
The average height of molecules is directly related to the pressure of the gas in the box. As the average height increases, the pressure also increases. This is because the molecules have more kinetic energy and collide with the walls of the box more frequently, creating a higher pressure.
5. Can the average height of molecules in a box be used to determine the temperature?
No, the average height of molecules in a box cannot be used to determine the temperature. This is because the average height also depends on the size and mass of the molecules, not just the temperature.
