Average momentum of an avalanche
  • Thread starter Thread starter I_Try_Math
    Momentum
The discussion centers on calculating the average momentum of an avalanche, with a focus on understanding the correct formula and units. The initial calculation provided was incorrect due to a misunderstanding of average momentum, which should be defined as mass times average velocity (mv_avg). Participants noted that the original answer lacked proper units, leading to confusion about its validity. After reevaluating the calculations and incorporating the correct units, the user was able to arrive at the textbook's answer. This highlights the importance of unit consistency in physics calculations.
I_Try_Math
What is the average momentum of an avalanche that moves a 40-cm-thick layer of snow over an area of 100 m by 500 m over a distance of 1 km down a hill in 5.5 s? Assume a density of 350 kg/ m^3 for the snow.
##\rho## = mv
##m_s## = mass of snow
##V_s## = volume of snow
##\vec{v}## = velocity of snow
D = density of snow
##\rho_{avg} = \frac{\rho}{V_s}##
##=\frac{m_s \vec{v}}{V_s}##
##=\frac{V_s D \vec{v}}{V_s}##
##=D \vec{v}##
##=350 \frac{1,000}{5.5}##
##=63,636.4##
The textbook's answer is ##1.3 \times 10^9##. I guess I must not be understanding what's meant by "average momentum" since my answer is wrong. Any help is appreciated.
I_Try_Math said:
Homework Statement: What is the average momentum of an avalanche that moves a 40-cm-thick layer of snow over an area of 100 m by 500 m over a distance of 1 km down a hill in 5.5 s? Assume a density of 350 kg/ m^3 for the snow.
Relevant Equations: ##\rho## = mv
D = density of snow
##=D \vec{v}##
##=63,636.4##
That calculation doesn't make a lot of sense. First things first: How would you define average momentum for an avalanche?
How do you know that your answer is wrong? You quote numbers without units so both you and the texbook can be correct in principle. Had you used units, you would have seen that momentum over volume, your starting equation, does not have units of momentum because it is divided by volume.
I suppose you could define it as ##mv_{avg}##?
That would work.
Likes PeroK, I_Try_Math and MatinSAR
Right I will keep that in mind. Found out my original answer has units ##\frac{kg}{m^2s}##. Obviously incorrect. I worked through it and got the correct answer.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
