Average number of memory accesses?
In summary: So is that two accesses then?In summary, the Unsorted-Optimized array structure is used to store a data set. To calculate its density, we need to consider its operations (insert, fetch, update, and delete) and the number of nodes (1,000,000) in the data set. Assuming all operations are equally probable, we can calculate the average number of memory accesses by dividing the total number of nodes checked for insert and update (n/2) by the total number of operations (4). However, there may be a problem in determining the exact number of memory accesses for insert and update as these operations require accessing both the nodes and the array of pointers.
Rijad Hadzic
321
The Unsorted-Optimized array structure is used to store a data set.
Calculate its density if:
Each of the client's nodes contains 200 bytes of information and there
are 1,000,000 nodes in the data set.
(This was the previous problem, the problem I'm doing is based on it though, :)
Give the average number of memory accesses of the Unsorted-
Optimized array structure whose data set is described in part (b) of
the previous exercise:
a) Assuming all operations on the data set are equally probable.answer choices:
375,008
750,002
70,022
50,002
So I know the operations are: insert, fetch, update, and delete.
I'm just lost on where to even start on this problem. Could someone please give me a hint?
I think we need to start by looking at part b of the previous problem.
You just need to calculate the average number of an insert, delete, fetch and update, and then compute the average of those 4 numbers.
It shouldn't be too hard if you know how these operations work. I think you use Data Structures and Algorithms using Java by William McAllister. In that case it should be clearly explained.
There is a bit of a problem however. In an Unsorted-Optimized optimized array, the most frequently accessed node references should slowly move to the start of the array, and this should make searching faster, but you can't really tell how much faster without knowing if there are any nodes that are accessed much more than others. If you ignore this, you can get one of the answers in the list, but if you don't I wouldn't know what the average is.
Part B of the previous problem is in my OP it just doesn't say part B. All of the relevant info is there.
Yes I am using Data Structures and Algorithms using Java by William McAllister. I actually do not like this book lol.
I still don't think I'm getting it.
So there are 1,000,000 nodes in the data set.
So there is a 1/4 chance I am doing fetch, 1/4 chance I am doing delete, 1/4 chance I am doing insert, and 1/4 chance I am doing update
for fetch and delete it is using a sequential search, so n/2 and n/2 for delete and fetch
but how do I know what it is for insert and update? it seems to me like those two arent memory accesses?
What I did so far:
n/2 = 500,000, which I divided by 4 since there is a 1/4th chance of it happening for fetch
so 125000
the same will happen to delete so I add 125000+125000 = 250000
I divide this by 4 since there is 4 operations, and get 62500 which is obviously not an answer.
How do I find the number of memory accesses for update and insert? and is my logic correct so far in how I'm calculating it??
When you search for a node, you have to check half the nodes on average. Does checking a node take a single access?
If you want to update something, you want to change it, so you have to know where it is.
what does insert do? Do you have to do something with the entire array?
Hmm this is a weird question. Nodes have multiple fields, but to check a node it only requires one access, correct? Because you are checking the node with a key or numeric mode, is why I think it requires only one access. Am I wrong in this thinking?
There are the nodes themselves, and there is an array of pointers to them. You will have to access both.
Related to Average number of memory accesses?
1. What is the average number of memory accesses?
The average number of memory accesses refers to the average number of times a computer accesses data stored in its memory in order to complete a task or process.
2. How is the average number of memory accesses calculated?
The average number of memory accesses is calculated by dividing the total number of memory accesses by the number of tasks or processes that require memory access.
3. Why is the average number of memory accesses important?
The average number of memory accesses is important because it can affect the overall performance and speed of a computer. A high number of memory accesses can slow down the execution of tasks and processes, while a low number can improve efficiency.
4. What factors can affect the average number of memory accesses?
The average number of memory accesses can be affected by various factors such as the type and speed of the computer's memory, the complexity of the tasks or processes being performed, and the efficiency of the computer's hardware and software.
5. How can the average number of memory accesses be optimized?
The average number of memory accesses can be optimized by using efficient algorithms and data structures, minimizing unnecessary data transfers, and optimizing the computer's hardware and software components.
11K
