Average Potential Electricity and Magnetism
The discussion focuses on calculating the average electric potential over a spherical surface due to a point charge located inside. The equation provided for the average potential, Vave, incorporates the potential at the center from external charges and the total enclosed charge. Participants express confusion about the mathematical derivation, particularly regarding the potential formula and the integration process over the spherical surface. Key points include the need to understand spherical coordinates and the correct application of the area element for integration. The conversation emphasizes the importance of clarifying these concepts to successfully solve the problem.
jrc5135
Find the average potential over a spherical surface of radius R due to a point charge q located inside. Show that in general: (EQ 1 below), where Vcenter is the potential at the center due to all external charges and Qenc is the total enclosed charge
EQ 1 Vave = Vcenter + (Qenc/4*pi*ε₀*R)
I am just really confused on where to at least get started. I'll be at the computer for awhile so feel free to ask questions I just want to get it started.
Try placing a point charge on the z-axis a distance z'<R from the origin. What is the potential V(\vec{r}) at a general point \vec{r} in spherical coordinates? Average this potential over the surface of a sphere of radius R. What do you get?
1/(4*pi*epsilon nought) q/r
Is it really?! I thought the potential due to a point charge located at \vec{r&#039;} was:
\frac{1}{4\pi \epsilon_0} \frac{q}{|\vec{r}-\vec{r&#039;}|}
Of course, when the charge is at the origin, \vec{r&#039;}=0 and the potential reduces to the one you gave. But(!) what about when the charge is located along the z-axis a distance z' from the origin (i.e.\vec{r&#039;}=z&#039;\hat{z} \neq 0) ??
not too sure?
Have you learned about vectors yet? If so, what is |\vec{r}-z&#039;\hat{z}| in spherical coordinates?
i really don't know?
you don't know if you've studied vectors yet?
I have and I know the potential outside the sphere has to only be in the +z direction because of symmetry, but I don't know the second part of your question.
Well,
|\vec{r}-z&#039;\hat{z}|=\sqrt{(r\hat{r}-z&#039;\hat{z}) \cdot (r\hat{r}-z&#039;\hat{z})}=\sqrt{r^2-2rz&#039; (\hat{r} \cdot \hat{z})+z&#039;^2}=\sqrt{r^2-2rz&#039;cos(\theta)+z&#039;^2}
\Rightarrow V(\vec{r})= \frac{1}{4 \pi \epsilon _0} \frac{q}{\sqrt{r^2-2rz&#039;cos(\theta)+z&#039;^2}}
And so on the spherical surface r=R,
\Rightarrow V(R,\theta,\phi)= \frac{1}{4 \pi \epsilon _0} \frac{q}{\sqrt{R^2-2Rdcos(\theta)+d^2}}
(where I have set z'=d the distance of the point charge from the origin)
Do you know how to average a function over a surface?
no i dont
The average of a function f(\vec{r}) over any surface \mathcal{S} is defined as
f_{ave}=\frac{\int_{\mathcal{S}} f(\vec{r})da }{\int_\mathcal{S} da}=\frac{1}{A} \int_{\mathcal{S}} f(\vec{r})da
where A is the area of the surface, and da is the infitesimal area element for said surface.
What is da for a spherical surface of radius R (in spherical coordinates)?
Can you apply this to V(R,\theta,\phi)?
da would be r^2sin(theta)drdtheta
so then
Vave = 1/a(integral (k q/r)*r^2sin(theta)drdtheta
Does r really vary on a spherical surface of fixed radius r=R ? If not, why is there a dr in your da ? Shouldn't there be a d\phi term instead?
And why are you using kq/r for V(R,\theta,\phi)?
What are the limits of integration for \theta and \phi?
