Average Speed and Free-Falling Objects
In summary: What is the distance fallen in 1 s?In summary, the conversation discussed the concept of average speed and the variables involved. It also included a problem involving an object being dropped from a height and finding its speed after 1 second. The answer to the dropped object problem depends on the distance fallen in 1 second.
Soaring Crane
469
A car is making a trip of 40 mi. It travels half the distance at an average speed of 20 mph. In order for it to have an average speed of 40 mph for the whole trip, the car would need to:
a. travel at an average speed of 40 mph for the trip’s remainder.
b. travel at an average speed of 60 mph for the trip’s remainder.
c. cover the remainder of the distance in 15 minutes.
d. It is not possible for the entire trip to have an average speed of 40 mph..
average speed = distance / delta time
Based on the mathematical definition of average speed, the time taken to travel the first 20 mi is:
Time = distance / average speed = 20 mi / 20 mph = 1 hr
The time required to travel the desired distance, 40 mi, with an average speed of 40 mph is:
Time = distance / average speed = 40 mi / 40 mph = 1 hr
For the first 20 mi, 1 hr has already elapsed; therefore, the total time to travel 40 mi will be longer than 1 hr. Is the correct choice d.?
An object at rest is dropped from a height of 10 m. After 1 s, what is the object’s speed? (g = 10 m/s^2)
v_f = v_o +a*t
v_f = v_o +a*t
v_o = 0 m/s
t = 1 s
a = -10 m/s^2
v_f = (-10 m/s^2)*(1 s) = |-10 m/s| = 10 m/s ?
Thank you.
The car problem is correct.
For the dropped object, you might or might not be correct. What is the object's speed after it has fallen 10 m?
I don't quite understand your posed question. Wouldn't the object be at rest once it lands 10 m below the building?
Or do you want me to find v_f with the equation (v_f)^2 = (v_o)^2 + 2*a*(delta x) in which v_f = sqrt[2*(-10 m/s^2)*-10 m]?
Yes, exactly. So the answer is either 0, or the 10 m/s you calculated. It depends on whether the object has fallen 10m in 1 s.
FAQ: Average Speed and Free-Falling Objects
1. What is average speed?
Average speed is the total distance traveled divided by the total time it took to travel that distance.
2. How is average speed different from instantaneous speed?
Average speed is the overall rate of motion over a given distance, while instantaneous speed is the speed at a specific moment in time.
3. How is average speed calculated for free-falling objects?
The average speed of a free-falling object is the sum of the initial velocity and the final velocity, divided by 2.
4. Does the mass of a free-falling object affect its average speed?
No, the mass of a free-falling object does not affect its average speed. All objects falling under the same gravitational force will experience the same acceleration and thus have the same average speed.
5. How does air resistance affect the average speed of a falling object?
Air resistance can slow down the acceleration of a falling object, resulting in a lower average speed. However, in a vacuum where there is no air resistance, all objects will have the same average speed when falling.
