Average value of a function and such.
In summary, we looked at the voltage in an electrical outlet given by the function V = V0 cos(120πt). We found the average value of the voltage over 3 seconds by taking the integral of the function and dividing by 3. Next, we looked at the root mean square voltage, which is commonly used by engineers, and found it to be V = √avg of V^2. Finally, we solved for V0 using the standard voltage of 110 volts in an American house.
hellothere123
31
The voltage V in an electrical outlet is given as a function of time, t, by the function V = V0 cos(120πt), where V is in volts and t is in seconds, and V0 is a positive constant representing the maximum voltage.
(a) What is the average value of the voltage over 3 seconds?
(b) Engineers do not use the average voltage. They use the root mean square voltage defined by V = √avg of V^2. Find V in terms of V0. (Take the average over 3 seconds.)
(c) The standard voltage in an American house is 110 volts, meaning that V = 110. What is V0?
the V0 is really V_o. and that is pi up there.
any help is appreciated. this is my set up:
(V_o)/3 [sin(120 pi t)/(120pi)][0 to 3]
(a) The average over 3 seconds can be found by taking the integral of V0 cos(120 PI t) from t=0 to t=3, and dividing your answer by 3. NOTE: you divide by the change in time, not by the change in argument to the cosine function. NOTE: this should come out to be very close to zero.
(b) Same as (a), but now the function you're integrating from 0 to 3 seconds is:
(V0)^2 cos^2(120 PI t)
You may want to use the fact that cos(2x) = cos^2(x) - sin^2(x) = 2cos^2(x) - 1.
Once you get the integral, then just divide by 3, and that's <V^2>.
Then take the sqrt and you're done.
(c) Well,
110 = <V^2> = f(V0)
is the equation you need to solve. You found f(V0) in part (b).
FAQ: Average value of a function and such.
What is the average value of a function?
The average value of a function is the value that represents the average output of that function over a given interval. It is also known as the mean value or the average of the function.
How do you find the average value of a function?
To find the average value of a function, you need to first find the definite integral of the function over the given interval. Then, divide this result by the length of the interval. The quotient will be the average value of the function.
What is the significance of finding the average value of a function?
The average value of a function is useful in understanding the behavior and trends of the function over a specific interval. It can also be used to compare different functions and their average values to determine which one has a higher average output.
Can the average value of a function be negative?
Yes, the average value of a function can be negative. This can happen when the function has a negative output over the given interval, which results in a negative definite integral and therefore a negative average value.
Is the average value of a function the same as the mean value?
Yes, the average value of a function and the mean value are two terms used interchangeably to describe the same concept. They both represent the average output of a function over a given interval.
