Avg Acceleration problem + question on Speed vs Velocity
In summary, the world-class sprinter has an average acceleration of 2.75-m/s^2 during the first 4.0 seconds of the 100-m race.
resjsu
1. A world-class sprinter accelerates to his maximum speed in 4.0s. He maintains this speed for the remainder of the 100-m race, finishing with a time of 9.1 seconds.
Find A] What is the runners average acceleration during the first 4.0 seconds.
2. Vx=Vox+AxT
X=Xo+VoxT+1/2AxT
Vx2=Vox2+2Ax(X-Xo)
X-Xo=((Vox+Vx)/2)T
3. I used 100-m/9.1 seconds and got 10.99m/s as his average velocity. Divided it by 4 seconds to get an Acceleration of 2.75-m/s^2 but it is wrong. The correct answer is 3.5-m/s^2. Without knowing what distance he covered in the first 4 seconds I am stuck.
Also, I've been having a little trouble understanding speed vs velocity how can average speed be different than average velocity? I read in my text that speed is the magnitude of velocity and that it cannot be zero. Also, that "speed denotes distance traveled divided by time..." Which is exactly what Velocity equals; so how can they be different?
2. Vx=Vox+AxT
X=Xo+VoxT+1/2AxT
Vx2=Vox2+2Ax(X-Xo)
X-Xo=((Vox+Vx)/2)T
Firstly Velocity is displacement divided by time. Also in a straight race, like the 100m, where the runners do not change direction, there does appear to be very little difference between speed and velocity.
During steady acceleration, your average velocity is simply (initial vel + final vel) x 2
being a straight line event we could also say
During steady acceleration, your average speed is simply (initial speed + final speed) x 2
As you said your average speed is simply distance over time, and in this straight-line event the distance covered is the magnitude of your diplacement for the time.
[Note: compare that to the first 4 seconds of a 200m race where all the runners are running around the bend. The distance covered is an arc, the displacement is simply a chord to the circle]
Another [impossible] was to achieve the same average velocity would be to remain stationary for the 1st 2 seconds, then magically and mysteriously blast off at full speed for the next two seconds. so a 9.1 second 100m race is equivalent to a 7.1 second trip at full speed, [compared to the 4 second build up then the 5.1 second cruise]
There is some food for thought.
NB: in the 400m men's final in the London Olympics next year, the runner in the outside lane will have the largest average velocity.
Being the final - all runners will have a time within 5% of each other, but the staggered start means the runner in the outside lane starts the greatest distance from the finish line. Indeed, if they have a runner in Lane 1, that persons average velocity for the event will be 0
The winner will have the highest average speed!
Thank you for the reply but it is still confusing. Even in your reply you make it sound like speed and velocity are the same? Could you explain it a bit with the values in the problem above?
Also in a 400 meter doesn't everyone run... 400 meters?
The 400m race best indicates the difference between speed and velocity.
We could best demonstrate it by having competitors run directly from their starting point, to their finishing point.
In the 100m sprint, that change would make no difference at all. Why - because the competitor never changes direction.
For the 400m race, it is very different.
Lane 1: start and finish point are one and the same place.
Lane 2: finish is about 8m behind the start point - around a bend.
Lane 3: finish is about 16m behind the start point - around a bend
For the marathon, some events the finish is several km from the start, but at the Olympics, where competitors often begin by running a few laps of the stadium before going out onto the streets only to return a couple of hours later and do one last lap of the stadium, the finish may also be the same place as the start [though often such races start on the opposite side of the Stadium to the finish].
In Australian Football, players have been tracked to find they run over 10km during the game - which lasts about 2 hours.
That would give an average speed of over 5 km/h
However the final position of the player may turn out to be the same as the starting position - standing in goal - so his average velocity for the game is zero.
Indeed the player with the highest average velocity will be the injured player taken to hospital [5 km away] during the first minute of the game!
[/b]
I can help clarify the concepts of speed and velocity for you. In the first problem, we are given the time and distance for the runner's race, and we are asked to find the average acceleration during the first 4.0 seconds. To do this, we can use the formula a = (Vf - Vi)/t, where Vf is the final velocity, Vi is the initial velocity, and t is the time. In this case, we know that the final velocity is the same as the average velocity, so we can use the formula Vavg = (Vf + Vi)/2. Plugging in the given values, we get 3.5 m/s^2 as the average acceleration during the first 4.0 seconds.
Now, onto the concept of speed vs velocity. While they may seem similar, there is a subtle difference between the two. Speed is a scalar quantity, meaning it only has magnitude, while velocity is a vector quantity, meaning it has both magnitude and direction. In other words, speed tells us how fast an object is moving, while velocity tells us both how fast it is moving and in what direction. This is why we use different symbols for them (v for speed, and v with an arrow on top for velocity).
In the case of average speed vs average velocity, the difference lies in the fact that speed is calculated by dividing the total distance traveled by the total time taken, while velocity is calculated by dividing the displacement (change in position) by the total time taken. In other words, speed takes into account the entire path traveled, while velocity only considers the net displacement.
To better understand this, let's take an example. Say a car travels 100 km in 2 hours, then turns around and travels back to its starting point in another 2 hours. The total distance traveled is 200 km, and the total time taken is 4 hours. Therefore, the average speed is 200 km/4 hours = 50 km/h. However, the net displacement (change in position) is 0 km, since the car ends up at the same spot it started. Therefore, the average velocity is 0 km/4 hours = 0 km/h. This is why average speed can be different than average velocity.
I hope this helps clarify the concepts of speed and velocity for you. Remember, as a scientist, it's important to pay attention to the units and
Related to Avg Acceleration problem + question on Speed vs Velocity
1. What is the difference between speed and velocity?
Speed is a measure of how fast an object is moving, while velocity is a measure of how fast an object is moving in a specific direction. Speed is considered a scalar quantity, while velocity is a vector quantity.
2. How do you calculate average acceleration?
Average acceleration is calculated by dividing the change in velocity by the change in time. The formula is: average acceleration = (final velocity - initial velocity) / time.
3. What is an acceleration problem?
An acceleration problem is a physics problem that involves calculating the acceleration of an object. This can include determining the average acceleration, initial or final velocity, or time taken for an object to accelerate.
4. How can you tell if an object is accelerating?
An object is considered to be accelerating if its velocity is changing. This can be observed by noticing a change in speed or direction of an object's motion.
5. Can an object have a constant speed but changing velocity?
Yes, an object can have a constant speed but changing velocity. This occurs when the object is moving in a curved path, such as a circular motion. The speed remains constant, but the direction of motion changes, resulting in a changing velocity.
