AZING! Conservation of Energy and Velocity in Tarzan's Swing
  • Thread starter baileya
  • Tags
    Velocity
In summary, Tarzan swings from his tree house to Jane's by hanging on a 22m long vine with a frictionless swing. The angles between Tarzan's house and the bottom of his swing and between Jane's house and the bottom of Tarzan's swing are 60 degrees and 40 degrees, respectively. To find his velocity at the bottom of his swing and when he reaches Jane's place, we can use the conservation of energy principle. The difference in potential energy between his tree house and the bottom / Jane's place is converted into kinetic energy, and thus energy is conserved.
baileya
Tarzan swings from his tree house over to Janes by hanging on a vine that's 22m long. Assume his swing is frictionless (conservative forces only). The angle between Tarzan's house and the bottom of his swing is 60 degrees, the angle between Jane's house and the bottom of Tarzan's swing is 40 degrees.
What's his velocity at the bottom of his swing?
What's the velocity when he gets to Janes place?
PEg=mgyi
mgyi+1/2mvi^2=mgyf+1/2mvf^2
I attempted to figure it out using examples from notes, but got nowhere.
A very detailed, simple explanation would be great (I really can't figure it out!)
Use conservation of energy. What is the difference in potential energy between his tree house and the bottom / Jane's place? Is energy conserved? If so, what form of energy is that difference in potential energy converted to?
AM
FAQ: AZING! Conservation of Energy and Velocity in Tarzan's Swing
1. What is velocity?
Velocity is a measure of the rate of change of an object's position with respect to time. It is a vector quantity, which means it has both magnitude (speed) and direction.
2. How is velocity different from speed?
While both velocity and speed measure how fast an object is moving, velocity also takes into account the direction of motion, whereas speed does not. In other words, velocity is a vector quantity, while speed is a scalar quantity.
3. How is velocity calculated?
Velocity is calculated by dividing the change in an object's position by the time it took for that change to occur. It is represented by the equation v = Δx/Δt, where v is velocity, Δx is the change in position, and Δt is the change in time.
4. What are the units for velocity?
The standard units for velocity are meters per second (m/s) in the metric system and miles per hour (mph) in the imperial system. However, other units such as kilometers per hour (km/h) and feet per second (ft/s) are also commonly used.
5. How is velocity used in science?
Velocity is a fundamental concept in physics and is used in many different fields of science, including mechanics, thermodynamics, and astronomy. It is crucial in understanding the motion of objects and predicting their future positions and behaviors.
