MHB B.1.2.3 Find the equilibrium solution and....
  • Thread starter Thread starter karush
    Equilibrium
karush
MHB
$\tiny{b.1.2.3}$
Consider the differential equation
$\displaystyle \dfrac{dy}{dt}=ay-b$
Find the equilibrium solution $y_e$ rewrite as
$y'=ay-b=0$
then
$ay-b=0\implies y_e=\dfrac{b}{a}$
(b) Let $Y(t)=y-y_e$;
thus $Y(t)$ is the deviation from the equilibrium solution.
the differential equation satisfied by $Y(t)$.
so far but ?here is the book answer
karush said:
$\tiny{b.1.2.3}$
$y'=ay-b=0$
then
so far but ?
If Y= y-y_e the y= Y+ y_e.
Y'= y'= ay- b= a(Y+ y_e)= a(Y+ b/a)= aY+ b.
Y also satisfies the equation Y'= aY+ b.
With y'= dy/dx= ay+ b, dy/(ay+b)= dx.
To integrate the left, let u= ay+ b so that du= ady. dy= (1/a)du and the equation becomes
(1/a) du/u= dx
(1/a) ln(u)= x+ C
ln(u)= ax+ aC
u= e^{ax+ aC}= e^{aC}e^{ax}= C'e^{ax} where C'= e^{aC}
ay+ b= C'e^{ax}
ay= C'e^{ax}- b
y= (C'/a)e^{ax}- b/a= C''e^{ax}- b/a where C''= C'/a.
If a increases, the equilbrium, b/a, decreases but e^{ax} increases faster so y increases faster.
If a decreases. the equilibrium, b/a, increases but e^{ax} decreases slow so y increases slower.
mahalo helps a lot
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
