MHB -b.2.1.11 Find the general solution y'+y=5sin{2t}
karush
MHB
Find the general solution of the given differential equation, and use it to determine how solutions behave as $ t\to\infty$ $y'+y=5\sin{2t}$
ok I did this first
$u(t)y'+u(t)y=u(i)5\sin{2t}$
then
$\frac{1}{5}u(t)y'+\frac{1}{5}u(t)y=u(i)\sin{2t}$
so far ... couldn't find an esample to follow
____________________________________________
book answer
$y=ce^{−t}+\sin 2t−2\cos 2t$
$\textit{y is asymptotic to sin2t−2cos2t as $t\to\infty$}$
$y' + a(t) \cdot y = b(t)$
$y' + y = 5\sin(2t)$
integrating factor is $e^{\int a(t) dt} = e^{\int dt} = e^t$
$e^t y' + e^t y = 5e^t \sin(2t)$
$\displaystyle (e^t y)' = 5e^t \sin(2t) \, dt$
$\displaystyle e^t y = 5 \int e^t \sin(2t) \, dt$
integrate the right side by parts (2 iterations which I'm not typing out)
$e^t y = e^t[\sin(2t)-2\cos(2t)] + C$
$y = \sin(2t)-2\cos(2t) + Ce^{-t}$
$t \to \infty \implies Ce^{-t} \to 0$
Appreciate much😎
I have never been a fan of using the "integrating factor" for something as simple as linear differential equations with constant coefficients. The "associated homogeneous equation" is y'+ y= 0 which has characteristic equation r+ 1= 0 so characteristic root r= -1. The general solution to the associated homogeneous equation is $y(t)= Ce^{-t}$.
Now, recognizing "sine" and "cosine" together as one of the types of solutions we expect for such equations, we seek a solution to the entire equation of the form $y= Acos(2t)+ Bsin(2t)$. We need to determine A and B. Then $y'= -2Asin(2t)+ 2Bcos(25)$ so the equation becomes $y'+ y= -2Asin(2t)+ 2Bcos(2t)+ Acos(2t)+ Bsin(2t)= (A+ 2B) cos(2t)+ (B- 2A)sin(2t)= 5 sin(2t)$. Since this is to be true for all t we must have A+ 2B= 0 and B- 2A= 5. 2 times the first equation gives 2A+ 4B= 0 and adding the second equation eliminates A: 5B= 5 so B= 1. Then A+ 2B= A+ 2= 0 so A= -2.
$-2cos(2t)+ sin(2t)$ satisfies the entire equation so the general solution to the entire equation is $y(t)= Ce^{-t}- 2cos(2t)+ sin(2t)$.
As t goes to infinity, $Ce^{-t}$ goes to 0 for all C so this solution "behaves like" $sin(2t)- cos(2t)$.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
