MHB -b.2.2.26 IVP min value y'=2(1+x)(1+y^2); y(0)=0
  • Thread starter Thread starter karush
    Ivp Value
The initial value problem (IVP) y' = 2(1+x)(1+y^2) with y(0)=0 is solved by separating variables and integrating, resulting in y = tan(2x - x^2). To find the minimum value of the solution, the derivative y' is set to zero, leading to x = -1 as the critical point. The second derivative test confirms that this point is a minimum since y'' is positive at x = -1. The book states that the minimum value of the function is -1. The discussion emphasizes the importance of using derivatives to determine extrema in differential equations.
karush
MHB
Solve the IVP $y'=2(1+x)(1+y^2),\quad y(0)=0$
$\begin{array}{ll}
\textit{separate variables}&
\displaystyle
\left(\dfrac{1}{1+y^2}\right)\ dy
=2(1+x)\ dx\\
\textit{integrate thru}&
\arctan \left(y\right)=2x+x^2+c\\
\textit{plug in x=0 and y=0}&
\arctan 0=0+c\\
&0=c\\
\textit{thus the equation is}&
y=\tan(2x-x^2)
\end{array}$
find where solution attains minimum value
ok wasn't sure about the tangent thing
book answer for min value is -1 but ?
By the time you are studying differential equations, you should know that the standard method for finding a minimum, or maximum, value for a function is to set the derivative equal to 0.
Here, you are told immediately that the derivative is $y'= 2(1+ x)(1+ y^2)$. Setting that equal to 0, $2(1+ x)(1+ y^2)= 0$. Since $1+ y^2$ is never 0 we must have x= -1.
Add: To check whether x= -1 gives a max or min, use the "second derivative test". $y'= 2(x+ 1)(1+ y^2)$ so $y''= 2(1+ y^2)+ 2(1+ x)(2yy')$. At x= -1 that is $y''= 2(1+ y(-1)^2)$ which is positive no matter what y(-1) is. Therefore x= -1 gives a minimum.
ok ill try that on the next one
