MHB -b.3.1.1 find the general solution of the second order y''+2y'-3y=0
karush
MHB
$\tiny{3.1.1}$
find the general solution of the second order differential equation.
$$y''+2y'-3y=0$$
assume that $y = e^{rt}$ then,
$$r^2+2r-3=0\implies (r+3)(r-1)=0$$
new stuff... so far..
karush said:
$\tiny{3.1.1}$
$$y''+2y'-3y=0$$
Good so far. So r = -3 and r = 1. Therefore two linearly independent solutions would be [math]y = e^{-3t}[/math] and [math]y = e^{t}[/math].
One last little bit for you. We have two linearly independent solutions to a second order linear homogenous differential equation. How do you write down the general solution?
-Dan
-Dan
$$y=c_1e^{-3t}+c_2e^{t}$$
guess that's it?
what is linear independent solutions?
guess that's it?
Yes, that's it.
Let f(t) and g(t) be differentiable functions. Then they are called linearly dependent if there are nonzero constants c1 and c2 with [math]c_1 f(t) + c_2 g(t) = 0[/math] for all t. If they are not linearly dependent then they are linearly independent.
-Dan
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
