B and H field concept question (saturation)
In summary: Ferromagnetic materials can have a saturation point because they have a very strong tendency to lock onto and maintain a certain flux.
Tabur
Hi there!
I need some help in understanding the relationship between B and H fields and their "physical" meaning (helps me visualize problems). I'll try to be as clear as possible about my current knowledge and my questions:
  1. "Fields" do not exist, they are just a mathematical parametrization of the Force (or any) vector generated by a certain body at a point in space and time. For instance, if the force between two (punctual) charges is:
    [itex]\vec{F} = \frac{q_1 q_2 \vec{r_{1,2}}}{|\vec{r_{1,2}}|^3}[/itex]
    then we can define a mathematical relationship F/q2 that we call "Field" (in this case E) so then we can generalize the force made by q1 in space to any charge q2.
  2. From what I gather H fields, H being the Magnetic Intensity field, are independent from the material they are in and depend only on the generating current, distance and geometry of the wire that generates it (ampere's law).
  3. [itex]\nabla \cdot \vec{B} = 0 [/itex] since magnetic flux density is defined as [itex] d \phi = \vec{B} \cdot d \vec{S}[/itex] and there are no magnetic monopoles. Magnetic flux [itex]\phi[/itex] is also fictional but it's still a flux and therefore we can define [itex]\vec{B} [/itex]. (Gauss' Law for magnetism)
  4. Magnetic field density is also defined for every material and point in space as:
    [itex] B = \mu _0 ( H + M ) = \mu _0 (1 + \chi _m) H[/itex] (and I REALLY don't understand this one)
Then my questions are:
1.- Which field is conserved in a magnetic circuit with big reluctances (and why)?
2.- What's the physical meaning of the reluctance?
3.- How is it possible for ferromagnetic materials to have a B saturation point? (and this one really puzzles me). I mean, if B = (1+x)*H*mu0 then how can it stop increasing when I increase H (or the magnetic field generating current). Does the excess flux surround the material?
and finally:
4.- If I have a magnetic circuit formed by a ferromagnetic material (initially demagnetized) and I want to generate a certain flux (in Webers) then which field is constant across the circuit, B or H? (I have the B-H curve of the material, now I just need to know which one is constant across the circuit since there's an air gap).
It's a long set of question but I'd really appreciate it if you could help me (and I'm sure thousands of other people have the exact same questions)
Thanks a lot!
It's shady to say that the fields don't exist... E and B both manifest themselves as light. You would have to decide on what you mean by exist... A lot of physicists would argue that E and B are real entities.
Seriously? Thats what you picked out of the whole post?
Could someone please explain to me any of the 4 questions I posted?
Yep, I couldn't agree more with jfy4. The electromagnetic field is a dynamical object at its own right!
I can only talk about point 3. There is a saturation point in materials because the equation you listed is only valid for LINEAR materials. This is the most simple model; however, many materials are not linear (and all materials are linear only up to a certain range of field strength, no material can provide infinite surface current). The non-linearity of the B and H relationship can get quite complicated, and indeed many materials will exhibit hysteresis in the B vs H relationship (which means that the B present, given an H depends on how you got to that H).
Related to B and H field concept question (saturation)
1. What is the B field?
The B field, also known as the magnetic field, is a vector field that describes the strength and direction of the magnetic force at any given point. It is typically measured in units of Tesla (T) or Gauss (G).
2. What is the H field?
The H field, also known as the magnetic field intensity, is a vector field that describes the magnetic field created by a current-carrying conductor. It is typically measured in units of Ampere per meter (A/m).
3. What is the relationship between B and H fields?
The B and H fields are related by the permeability of the material they are passing through. The B field is equal to the product of the permeability and the H field, or B = μH, where μ is the permeability.
4. What is saturation in relation to the B and H fields?
Saturation is a phenomenon that occurs when the magnetic material reaches its maximum ability to be magnetized. At this point, increasing the H field will not result in a proportional increase in the B field, and the material is said to be saturated.
5. How does saturation affect the B and H fields?
When a material is saturated, it has reached its maximum ability to be magnetized and can no longer increase its magnetic field strength. This can affect the overall strength and behavior of the B and H fields in a system, and can also impact the efficiency of magnetic devices such as transformers and motors.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Electromagnetism
