jack476
- 328
- 125
Thread moved from the technical forums, so no Homework Template is shown
I'm getting ready for the exam that's coming up and I just took the 2017 practice exam to see what the last gaps are that I need to fill.
Question 96 of this exam asks: "The magnetic field inside a long coil of wire (solenoid) has a certain magnitude and direction when the coil is air filled. If a diamagnetic material is inserted in the coil, how do the magnitude and direction of the magnetic field change?"
The possible answers were:
A: Magnitude increases, direction is the same
B: Magnitude increases, direction is opposite
C: Magnitude decreases, direction is the same
D: Magnitude decreases, direction is opposite
E: Magnitude is unchanged, direction is opposite.
My (incorrect) reasoning was that since B = μH and μ increases while H is independent of the material, I assumed that the answer was A. This is incorrect, and the correct answer is C. My first mistake was to assume that "magnetic field" referred to B rather than to H, and second to assume that since the magnetic field is independent of the material, B would increase if μ increases.
As I now understand it, the correct reasoning would have been to recognize that inserting a diamagnetic core into a solenoid doesn't change the value of B within the solenoid, and therefore since μ has increased, H must decrease, and here "magnetic field" refers to H.
Anyway, the reason that I'm confused is that in my classes, B was often referred to as the "magnetic field", but apparently on the PGRE "magnetic field" means H.
So my question is: On the Physics GRE, if it asks me about the "magnetic field", does this always mean H?
