B field due to a wire with an alternating current
In summary, the magnetic field a distance r from a long, thin wire carrying an alternating current I(t) = I_0 \sin \omega t is given by \vec B(r) = \frac{\mu_0 I_0 \sin \omega t}{2 \pi r} \hat \phi. The DC and AC results are the same in this case, as the induced EMF and time-average power do not affect the calculation of the magnetic field.
AxiomOfChoice
533
I need to find the magnetic field a distance [itex]r[/itex] from a long, thin wire carrying a current [itex]I(t) = I_0 \sin \omega t[/itex].
Field a distance [itex]r[/itex] from a wire carrying a steady current [itex]I[/itex] in the [itex]z[/itex] direction:
[tex]
\vec B(r) = \frac{\mu_0 I}{2 \pi r} \hat \phi
[/tex]
I'm tempted to say that, in the case of the alternating current,
[tex]
\vec B(r) = \frac{\mu_0 I_0 \sin \omega t}{2 \pi r} \hat \phi,
[/tex]
but I'm not sure I'm right, and I certainly can't explain to myself why it should be Ok to assume that the DC result will be the same as the AC result. My HW problem is actually very complicated: There's a lot of stuff involving induced EMF and time-average power. But I think I'm golden on this problem if I can just figure out what the [itex]\vec B[/itex]-field should be. Thanks!
I think you are right. Inductance effects will cause the AC potential across the wire to be different from the DC, but you are given current and it directly causes the B field so it shouldn't matter whether DC or AC.
I would first clarify that the equation for the magnetic field due to a steady current in a wire, \vec B(r) = \frac{\mu_0 I}{2 \pi r} \hat \phi, assumes that the current is constant and not changing over time. In the case of an alternating current, the current is continuously changing, so the equation for the magnetic field would also need to take into account this time-varying aspect.
One way to approach this problem would be to use Maxwell's equations, specifically the Ampere-Maxwell law, which states that the curl of the magnetic field is equal to the current density. In this case, the current density is changing over time due to the alternating current, so the magnetic field would also be changing over time.
Another approach would be to use the Biot-Savart law, which describes the magnetic field due to a small element of current. This law can be applied to each small element of the wire, taking into account the changing current over time, to calculate the total magnetic field at a distance r from the wire.
In either case, it is important to keep in mind that the magnetic field will not have a constant magnitude or direction due to the changing current, and will instead vary over time. It is also important to consider the direction of the magnetic field, as it will not necessarily be in the same direction as the current, but will depend on the geometry of the wire and the direction of the current.
In summary, the equation you have proposed, \vec B(r) = \frac{\mu_0 I_0 \sin \omega t}{2 \pi r} \hat \phi, is not a complete or accurate representation of the magnetic field due to an alternating current in a wire. Further analysis and consideration of the time-varying aspect of the current is necessary to accurately describe the magnetic field in this situation.
Related to B field due to a wire with an alternating current
1. What is the B field due to a wire with an alternating current?
The B field, also known as the magnetic field, is a vector field that describes the magnitude and direction of the magnetic force on a moving charged particle. In the case of a wire with an alternating current, the B field is created by the flow of electric current through the wire and is perpendicular to the direction of the current.
2. How is the B field affected by the direction of the current in the wire?
The direction of the B field is determined by the right-hand rule, which states that if you point your right thumb in the direction of the current, the curling of your fingers will indicate the direction of the B field.
3. What factors affect the strength of the B field around a wire with an alternating current?
The strength of the B field depends on several factors, including the magnitude of the current, the distance from the wire, and the frequency of the alternating current. The B field is strongest near the wire and decreases as the distance from the wire increases.
4. Can the B field be canceled out or neutralized?
Yes, the B field can be canceled out or neutralized by placing another wire with an alternating current in the opposite direction next to the original wire. This is known as anti-parallel currents and will result in a net B field of zero between the two wires.
5. How is the B field affected by the shape of the wire with an alternating current?
The shape of the wire does not significantly affect the B field. As long as the wire is straight and the current is flowing in the same direction, the B field will be the same. However, if the wire is curved or coiled, the B field will be stronger near the curves and weaker near the straight sections.
